Thread: atc 125m moves at low idle (auto clutch??)
    Oct 2012
    Upstate NY USA
    118
    my 125m automatic clutch (or something) wont stop moving even at low idle. It acts like the auto clutch stays engaged. exactly backwards of what Id expect a worn clutch to do.
    I just replaced the case half to fix a broken shift stop boss and also replaced the dry clutch disks. any idea why the automatic clutch wont disengage. If I got the external clutch assembled improperly would that do this. I can ride it but the shifter now acts like a real clutch... only way bike wont move is in neutral..... hmmm... i did replace the oil with regular oil (not ATV) but this never did this before...
    any ideas?
    thanks,
    Chris
    Thanks,
    Chris
    84 125m
    83 185s
    83 185s
    83 185s
    84 200es
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    731
    Chris,
    I put a new clutch in my 200M about a year ago. New shoes and friction plates. I havent been able to ride it much since then at all, so it does pull at idle. I think it just needs to be ridden a bit for stuff to wear in. I know it is adjusted right.
    With yours, I would check the clutch adjustment. I do not believe that you assembling the friction plates wrong would cause this problem, but it is possible. Maybe if you didnt torque stuff down properly, or didnt stack the clutch plates properly? It may just need to wear in some, but if you are grinding gears at all I wouldnt ride it. I would definitely run only ATV oil that is meant for use on wet clutches. It will say on the can.
    Let us know if that works.
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    Nov 2004
    Waterloo IL
    2,701
    I think I may know what your problem is. I just ran into this on an ATC110 I just picked up. I searched high and low for an answer with no luck and finally had to dig into it. Did you happen to put your steel clutch plates back in the order displayed from a parts diagram like the one in this link? If so the parts diagram is wrong. Number 8 and 9 are swapped. If you have an actual repair manual they are shown in the correct order, at least mine is. So someone was obviously in my bike before I bought it and put it back together according to a parts diagram which is wrong. My clutch would work correctly if I put about two turns of preload on the clutch adjustment rather than having free play. I knew that wasn't worth a crap so that's when I took it apart.
    http://www.bikebandit.com/oem-parts/.../m1875sch10666
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Oct 2012
    Upstate NY USA
    118
    Quote Originally Posted by BarnBoy View Post
    Chris,
    Thanks for the reply. Its possible but i think i just reassembled in reverse of taking apart but i dont remember for sure... I can try the ATV oil with the friction modifiers... maybe the weight spring broke or is hung up?? hmmm
    Thanks,
    Chris
    84 125m
    83 185s
    83 185s
    83 185s
    84 200es
    Oct 2012
    Upstate NY USA
    118
    thanks for the idea... I do have a manual so I can check...
    Quote Originally Posted by Blown 331 View Post
    Thanks,
    Chris
    84 125m
    83 185s
    83 185s
    83 185s
    84 200es
