So i bought a china carb...should a transfer all the oem jets/slide etc over to the new carb body?
Also my wiring is messed so i only get spark when the switch in in the "run" position. Can you start the bike up in "run" mode or do you have to begin with the switch on "start"?
Ive only been able to get the trike to run for a quick second with starting fluid and it was on "run"..it idles for a quick second and started moving forward.
Also is there supposed to be a gasket between the crankcase and the recoil?
thanks
