Originally Posted by
Onetrackmind
While it's off the machine, you should fully disassemble it and clean it again.
I would soak it in a Chemtool bath, then clean out all of the passages w carb cleaner and compressed air. Make sure that you clean your jets too. I like to take a strand of thin wire and work all the holes in the slow jet to make sure they are open. Make sure that your choke assembly is really clean too.
Are you sure that your fuel screw (mixture) is set to factory? That is where you need to be initially.
Is your new slow jet the same size (number) as your old one?
If the above doesn't help, your float level may not be set right (you are getting SOME fuel in your bowl, but just not ENOUGH).
