Has anyone used these on a 200x yet or no? I know you can use them on 350x and atc250r forks.
http://www.3wheelerworld.com/showthr...lators-on-350x
I'd call racetech and talk to sales. If they make them for your bike (wich I'd bet they do) there worth every penny. Easy to install for your average garage mechanic or they can do it for you they are fair on pricing. Very helpful people.
Actually, I have figured out what to do following your build. Thanks!
I've got them in my 87 200X.
They are far more adjustable than I am at suspension testing but they seem to work allot better than stock and no more 20wt; I can run 5 or 7 synthetic now...
What settings are you guys running? I am in the same weight range as you.
I've got 15w oil in mine. Approx 10oz (5.5" from top of tube) and with the emulators I gave them about 1/4 turn more than racetech set them originally (stiffer) wich I think was 2.5 turns in. Also I have progressive springs 42kg rate.
Did you find some that work in the first gen 200x?When I called they told me none of them work.
How much do you guys weigh?
Chris
But will the 2nd gen work?When I contacted them,said non they have will fit.
Same fork in an 87 or a 83.
Just about .750 taller OAL on the 2nd gens, but all of them are 33mm forks....
They sell emulators for the second gen 200x?
