IMO, while a UNI filter is an excellent upgrade to trap dirt and debris, the fact that you keep your air box on makes extra air flow nil. The FMF will decrease back-pressure and therefore your exhaust gasses will be less/fresh charge more when the reverse sonic waves "stuff" your cylinder. The bridge relief doesn't really add performance as it gets rid of a larger bridge that typically acts as a heat synch and potential piston "seizer". Another, better, option would have been to drill oil holes in the piston along the bridge line for optimum lubrication. Bottom line, those don't really add up to major increases in jetting for your carb.
Again, when changing jets in your carb don't touch the needle clip and vice versa. Short of an electrical issue, I think you will find that varying your needle clip without changing anything else will point you in the right direction.
I have absolutely no idea what you are saying, but as mentioned, change only one thing at a time, then test it with that change before you change ANYTHING else. In the case of changing the needle position, it will have virtually zero affect on jetting at wide open throttle and since you are saying it burbles etc at wide open throttle, it means that the problem is not with the position of the needle. The varying needle positions are for very fine tuning only because they typically only make very small changes in performance. I would put the clip in the middle position or second from the top and leave it there until you fix the big problem.
Your oil ratio is not causing the dark color on your spark plug. The dark color typically suggests a very rich condition, however, plug can look darker than it normally would if there is an electric problem that is causing a miss. The problem now is that you said it ran worse when you put the smaller jet in yet your plug is still extremely dark and that it runs best with the stock jet but it still has a big problem on pavement at wide open throttle. If you are correct, this suggests that something other than jetting is causing the problem.
PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR AND THE ONLY PERSON ON 3WW WITHOUT AN EDIT BUTTON
not sure why that sentence got messed up i was on my phone in the garage i was saying that i test every clip setting after i change jets to get the best throttle response
yes i test on the street and in the horse pen after every change
thank you for putting in some good theory i really want to understand the pressures and thermodynamics of a a 2 stroke
by reverse sonic waves are you talking about scavenging or is it different in a 2 stroke
yes i am probably making it harder on myself by keeping the air box closed but i want to keep the bike trail capable
does it make sense that an electrical issue would behave differently on pavement then dirt
i think i am very close to dialing in the carb ive just been set back with the chain break
Yes of course, and I know you know how to jet a bike. I just didn't read every post, but the few I read of his seemed to me like he was referring to wide open throttle. If this is the case then he obviously has 2 areas to deal with, however, there is typically little point in changing the needle position if the main jet is way off. I set the main jet first then go to the needle etc. I think one difficulty for people here to be able to accurately diagnose the real source of the problem is the accuracy and detail of the info he is providing, but it can be difficult for some people to accurately test things and then explain a result in a useful way so we all just do the best we can.
PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR AND THE ONLY PERSON ON 3WW WITHOUT AN EDIT BUTTON OR A STAR
yes i test on the street and in the horse pen after every change i make
as for throttle position i am not getting any more power over half throttle
i think i am very close to dialing in the carb as i am making improvement ive just been set back with the chain break
Very interesting axeman24. These are the same issues I'm having with my 85' Tecate. Brand new biuld top and bottom, just can't get it to act right past half throttle. Running a pwk airstryker keihin carb. Driving me insane!
170 psi sounds on the edge of low.
Jetting is one change at a time. I know it's hard to be patient but it'll actually save you time. My jetting took 3 months but after i nailed it, i haven't touched it in 4 years.
Get an OEM CDI.
You're getting some good advice on this thread.
I had a great weekend riding the r in pa right now it hangs with my 350 but it can be a lot better. I just had to ride it
I will get a oem cdi as I got paid nicely from selling that r swingarm I put in classifies
Overall I good dam love the r
You guys are a huge help in getting it running right and I will get it and learn a bunch along the way
No real update here except I had fun on 3 wheels
Back to troubleshooting this week
Here's an update I got my case saver chain and chain slider now all dirty from riding all weekend
