Hey guys does anyone on here know at what temperature should the red overheat light come on? I have a new guage and would like to set the overheat warning at the right temp
73 atc 7084 ytm 200ern79 atc 70ytm 225 dratc 90
80 atc 110klt 250A84 atc 200es
85 atc 250es
I would also like to know the answer to this....
what gauge did you go with?
1983 Selvy 300R - Check out the Build Thread
1985/86 Tri-Z - Build Thread Coming Soon
1985 Tri-Z
1986 250sx
1985 ATC70
1985 ATC 200M
Youtube Channel "Lowe Off Road"
- Brandon
trailtech vapour its slightly on the expensive side but does everything such as speed,air temp,coolant temp,rpm,shift lights stop watch, run time, trip meter its really worth it, keep an eye on my tri z astro kit thread i will be updating that once i have it all installed
85 atc 250es
Ok cool.... i have been planning on getting the trailtech voyager which "i think" does all that plus it has a good trail map system on it which i think is cool... I will keep an eye on your build thread
1985 Tri-Z
1986 250sx
1985 ATC70
1985 ATC 200M
- Brandon
yes you are correct i was going to get that but its abit bigger and wouldnt fit in between my flex bars which is where i have it mounted so far they seem like a great product i just have to connect the speedo
85 atc 250es
ohhhh.... i didn't even think about that. I would love to see pictures of your mounted
1985 Tri-Z
1986 250sx
1985 ATC70
1985 ATC 200M
- Brandon
I just downloaded a Tri-Z manual from the link you posted (Thank you, by the way), and found your answer on pg. 5-13. The switch should have continuity, and turn on the light, at more than 105 +/- 3 degrees C (221 +/- 37.4 degrees F). As the coolant cools down, the switch should lose continuity, and turn off the light, at less than 98 degrees C (208.4 degrees F).
