85 250r
I was putting an oem stator in when i noticed my flywheel keyway was very messed up.
no amount of BFH use helped
i picked up a tiny cutting wheel for my dremel
SURGERY TIME
i had to put the bike vertical and remove the skidplate to get a good angle
i carefully made a cut down the center of the key
it tapped out easily after the cut was made
on a side note i noticed small scratches on my flywheel looks like someone grabbed it with a pipe wrench or something probably why it came loose and spun
are these scratches something i should worry about on my flywheel
