I just finished a rebuild of the top half of the motor i went to start it wouldn't so i checked every thing noticed when i kicked it over air comes back through the air box or where it sounds like its comeing from so help any ideas
If its coming out during the compression stroke then your valves aren't seating and you need to lap them.
1985 ATC125M: Parts
1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
1988 TRX250X
1983 ATC200E: Total Pile.
"Bout Tree Fiddy" Master of Thy 22RE
You don't necessarily need to lap your valves. You would adjust the valves first and go from there. Are you sure you timed the valves correctly?
Timing is off , cam lobes pointed down with the top cam sprocket bolt at 12 o'clock , piston top dead center and flywheel mark set on T
Ok thanks guys timeing was off but another problem occured i used the kick starter and it went all the way down then came all the way back up and hit the tire did it slide off the gear cuz the spring still winds up?
