The oil injections is solid on these machines, but I blocked them off when I was running my Tri-motos. Mix at 32:1. You'll need to rejet for the mixture, might need to go up a few sizes on the main and adjust your pilot. I've always swapped out carbs and rejetted them.
As for the cables, I made my own. http://flanderscables.com/ will sell you all the parts you need. There is a minimum order on parts. I'd suggest stocking up since everything is mega cheap.
Those carbs on the 125s are pretty restrictive... But so is the rest of the machine. There's a lot you can do to that 125 to get some good power out of it.
