Results 1 to 13 of 13
Thread: 1985 atc 125m oil leak
    Oct 2017
    Liberty,Nc
    83
    This rubber piece on the left side of my 1985 atc 125m is cracked and leaks major amounts of oil. Does anyone know what this rubber seal is called and how to go about replacing itClick image for larger version.
ID:	247281Click image for larger version.
    Nov 2015
    Davenport iowa
    1,144
    Welcome,
    It's pretty hard to tell from your pic where the oil is coming from. If it's a seal you will need to pull that side cover off and replace it, don't forget to order any other gaskets you will need when you put it back together.. Post another pic with some sort of mark on the excact spot of the leak, that will help narrow it down..
    Oct 2017
    Liberty,Nc
    83
ID:	247317 from what i can tell its coming out of that rubber plug thats circled
    Aug 2016
    East of Worcester ma
    1,328
    Hey mr bubbles, a little soap and water may help you find your leak.
    Breathers plugged?
    Too much oil in crankcase?
    Here's a couple pics that may help Click image for larger version.
ID:	247318 Click image for larger version.
ID:	247319 Click image for larger version.
    Not my pics/ wish i could help more but can't.
    Shep
    Oct 2017
    Liberty,Nc
    83
    I might have to much oil in there. Is oil even supposed to be on this side .? Ill try to get some better pics tomorrow also , eventually im going to have to do the top end and replace anything leaking .
    Aug 2016
    1,328
    Well a quick search i found this Click image for larger version.
ID:	247324 if its supposed to be dry in there (stator housing) you've got other issues. Just be patient the right guys that have some time will see this.
    Shep
    Oct 2017
    Liberty,Nc
    83
    Oo i hope mines not to badly messed up if it is in there but it still starts up on first 1-3 pulls but thank you for your help
    Apr 2014
    Edmond, KS
    2,534
    From what I can tell by your pictures, it looks like the crankcase breather to me.
    Oct 2017
    Liberty,Nc
    83
ID:	247329 maybe this picture is better idk
    6,726
    Looks like the stator wires to me , need to remove the cover , purchase a new gasket , clean it up real good and seal it with hondabond
    Oct 2017
    Liberty,Nc
    83
    Ive been looking around and i read that most oil leaks on this side are from the crankshaft oil seal i found the honda seal thats 45mmx60mmx9mm but its 20$ do you think that this one would be just as good Click image for larger version.
    Oct 2017
    Liberty,Nc
    83
    Alright ive looked at others some saying there is a crankcase seal others say there is not one and i dont understand here this seal kit for a 84-85 125Click image for larger version.
ID:	248170 it says crankcase seals but when i opened up my engine there are no crankcase seals Click image for larger version.
ID:	248171 so idek to be honest
    Nov 2015
    Davenport iowa
    1,144
    Hey bubbles sounds like you could benefit from a manual if you are getting that far into things.. it would explain things better than we can through this forum.. plus there's pictures.
