Results 1 to 15 of 24
Thread: '83 Honda 200e front shocks/fork
    Aug 2015
    Idaho
    838
    [emoji847] hi guys. Big red's got down time. Shock boot spilt in two some time ago. I've kinda babied it, since. Not sure what will end of it, yet. I'd like to start by taking it apart to have a look. Both shocks still compress ok, they don't go up all the way, unless I lift the front end.
    I haven't had any luck finding a certain thread. I vaguely remember it, but it did show them disassembled.
    I'm also having a difficulties viewing the service manual. I'm going to get that printed today, hopefully.
    If someone could help me find it, I would really appreciate it and think I'd be ok-for awhile.
    My great tape job lost its function in notime.
    Jun 2015
    stonecreek ohio usa
    654
    Looks like your bushings wore out. I had a 200 big red that did the same thing. I found out that is a common problem for these models. Some guys put different front ends on them. Well hope you find a solution
    Aug 2015
    Idaho
    838
    Quote Originally Posted by schlepp29 View Post
    Thanks, a different front sounds like a good idea to me, too. I'd like to look into these original ones, first. See what's going on in there and if they can be rebuilt. I don't jump it or anything like that. In fact, I really don't need suspension there. But welding it is very last resort.
    Jun 2015
    stonecreek ohio usa
    654
    Yeah I've seen them welded before some cobbed and some done nice. I'd still like to put mine back together as well. I've wondered with the right material if I could have some made on a lathe. I wondered about brass or a good nylon. I don't blame you for wanting to keep yours it looks super clean from what I could see
    Scootertrash's Avatar
    In the sticks
    4,638
    I swapped the front end out on one for a customer. I believe it was a 200M front end that was used for a replacement, I'd have to find the thread. That front suspension system sucks and no (or very, very few) parts are available to rebuild them. IIRC they only used those front ends for 2 years. But I could be wrong.
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    If you decide to swap out the front forks, this link may be helpful. http://www.3wheelerworld.com/showthr...front+end+swap
    Aug 2015
    Idaho
    838
    Yes, I'd be interested in seeing your thread, scooter-thx. I agree with a swap and remember the numerous times it has been mentioned about 82-83 being a poor design. If it's easier for now, to fix these, I'd like to.
    Thx tripledog for the thread. I didn't see that one in my search. This might be like 'looking for a needle in a haystack', but I saw a thread a time ago that showed the differences in all/most 200-series (s,m,e & es). I want to say you were involved in that discussion or at least around when that thread was brought up in another thread. Thank you guys, for the info.
    Aug 2015
    Idaho
    838
    They cleaned up ok. Little water in the right. None in left side. It'd be nice to just grease and put back together. What would you guys do?
    I've been looking for another front end and will continue searching.
    Also, would this be ok to use?
    Jun 2015
    stonecreek ohio usa
    654
    Slide your lower leg on and see how much play there is.
    Aug 2015
    Idaho
    838
    I just went to check: left leg has very little play. Right has about 1/8" of play. Good? Thx schlepp.
    Jun 2015
    stonecreek ohio usa
    654
    No problem, can you see the nylon bushings inside the lower legs? If so try and pull those out. Those are the pieces that are wore out.
    Jun 2015
    stonecreek ohio usa
    654
    The left leg has alot of pitting which will wear out another bushing. You may be better to find another front end. Good luck jd.
    Aug 2015
    Idaho
    838
    I appreciate the insight. Found some bushings:
    https://m.ebay.com/itm/Honda-ATC-OEM...%257Ciid%253A1
    Haven't located any boots, yet. Considering the way I use it and how long new bushings would last (idk?). It might cost a couple hundred to get it going for awhile. I'll ponder it today.
    Jun 2015
    stonecreek ohio usa
    654
    I wondered if that was possible
    Aug 2015
    Idaho
    838
    I got them smoothed out the best I could, this morning.
    Called dealer and boots will be here Friday. Ordered 4 bushings, too. Total cost-$180. I figured it's better than waiting for an upgrade. Thank you for your guidance 29. I was going to grease and go until you mentioned the play.
    Thx dude, sounds good. Im not sure, though. My skill level, might make a mess versus running them the way they are. I may try it. Which would be better, JB weld or solder?
