Page 5 of 7 FirstFirst ... 3 4 5 6 7 LastLast
Results 61 to 75 of 102
Thread: Xt550 trike conversion build thread
  1. #61
    plevib's Avatar
    plevib is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2015
    North Dakota, USA
    358
    Got some more stuff in today. For now I got the seat recovered
    Sent from my SM-G900V using Tapatalk
    Atc 500x for the win! (Hopefully.... one day)
  2. #62
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    I've never used plastidip on anything before but I know paint would crack on these fenders with how hard I'm gonna lean on them.... so I'm trying it out. We'll see how it looks
  3. #63
    HondaRidr's Avatar
    Salt Lake
    331
    I'm excited to see this coming together. It's one of the more unique builds on here
    Sent from my SM-G930T using Tapatalk
  4. #64
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    Quote Originally Posted by HondaRidr View Post
    Thanks man, me too! Getting to the final stretch.
    I should be like tearing the bike down and finishing welds but I couldn't resist a teaser of the final product haha. After this picture I took the tank back off and went flat black. (Should have went with my gut in the first place haha) The semi was way too glossy. Looked weird against the plastic.
  5. #65
    You could paint it flat black with gloss sides like where the decals would go that would give it a different look
  6. #66
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    Quote Originally Posted by big specht View Post
    Meh... too much work hahaha. It'll be covered in mud 10 minutes after I get it running anyways haha. I don't believe in trailer Queens!
  7. #67
    Connecticut
    1,605
    Quote Originally Posted by plevib View Post
    Looks like the exact LED lights we are going to use in my Tri-Z! We bought 8 lights for a crawler loader and when they came they slipped inside the headlight shell. Thanks for the pic on how you mounted them!
    Really nice build! Your getting to all the details to make this perfect!
  8. #68
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    Looks much less impressive now.... haha.... had a couple hours tonight. Got the top end apart, looking good so far. The cam chain tensioner is stripped. I ordered a replacement and a new chain. Bore looks so so but I think I'm gonna leave it alone. Cam is in very very nice shape, valves look fine. Lots of carbon, looks like this thing has been running rich which is always better than the alternative haha...
  9. #69
    Las Vegas, NV.
    2,452
    Impressive fab skills and work so far plevib! Keep at it.
  10. #70
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    Well... that sucks. I got the engine tore down, cleaned all the big components (I ordered a ultra sonic cleaner for the smaller parts cuz they suck to clean). I found that the counter balancer keyway was wallowed out. I figured I could grind it larger and fit a bigger key in it. So I moved on. well I was checking the bearings to make sure I didn't get any sand in them and.... found a bad one. Looked closer and it was caused by a crack in the case. So both of the cases on this engine are trash and I only bought a left side replacement. But on the bright side I found a set of cases with a damaged left side AND a counterbalancer for 70 bucks! Couldn't be more perfect or cheaper for my situation. So I unfortunately won't get the engine built this weekend like I was hoping.
    So the replacement cases are on order and since this sets me back anyways I ordered a set of rings too. I found oem for 40 bucks so I figured "while I'm in there" applies here haha.
    So I'm switching gears to the frame this weekend. My goal is to finish welding, paint, and hopefully have a roller at the end of the weekend
  11. #71
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    Gussets are done! As is the steering stop. Looks almost identical to my 84r turning radius. All the frame welds are done. Supper break and make sure there's nothing I'm forgetting then off to paint! So freaking excited!
  12. #72
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    A grinder and paint. ......
    Well, you know the rest
  13. #73
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    I decided I could see the linkage possibly causing my bracket to flex or bend so I added a couple more bolts.
    That's the difference between an engineer and a fabricator. An engineer says "how can I make this cost efficient and light and still accomplish the task?" A fabricator says "meh, I'll just add some more metal there to stiffen that up...." haha
  14. #74
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    Back in black
  15. #75
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    Got a roller. Hopefully all my motor parts come in this weekend
