Results 46 to 53 of 53
Thread: Synthetic Two Stroke Oil Warning
  1. #46
    Blossvale NY
    4,567
    I ran some of my leftover 250r mix (60% 91 E-free, 40% Sunoco 110 and Maxima 927 at 32:1) in my chainsaws recently... made me want to put the saws down and go braappin'!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
  2. #47
    I've been using Golden Spectro since I first started to ride, 25 years now. People always ask me why I still use Golden Spectro and I always ask them why they aren't.
    Oct 2013
    New Hampshire
    77
    I did use spectro from the beginning and then went to bel,ray mc51, now I just experiment with different oil mostly just notice my silencer has more or less spluge. Performance hardly notice difference.
  4. #49
    Mexico
    9,012
    Ever use it on a power valve engine? Just wondering as PJ1 Gold plugged my PV up so bad I had to grind the crud off. This Motul leaves a thin crust on the PV in the low velocity areas and the high velocity areas clean up to bare metal with a rag.
    Lot of pro level guys swore by Golden Specto back before there were PV’s, but aside from one non PV engine never seen what a well used Golden Specrto motor looks like.
  5. #50
    That's because they never need to come apart.
    I don't have enough time on an engine with a power valve to know. I'm pretty sure the only power valve equipped engine I've ever had is our 86 KX500 powered 85 Tecate and that wasn't run very long.
