Results 1 to 15 of 19
Thread: DG Water Cooled Head for 81-84 ATC 250R
    Arizona
    843
    I thought you guys might like to see a rare piece of 3-wheeler history. This is a DG water cooled head for the 1st and 2nd generation ATC 250R. The coolant circulates using the thermosiphoning effect. Hot water is less dense so it rises to the top of the radiator, while the cooler water at the base of the radiator flows down to the head. I was worried the circulation wouldn’t be very efficient but after running it, one hose is clearly a lot hotter than the other. It’s a high compression head like the DG gold head, so I think it will run best on some ratio of race and pump gas. I haven’t had a chance to take it out for a real ride yet, but so far I’m very impressed with how much grunt it gives the R. Plus it just looks cool as hell. I love rare old school parts.
ID:	247802Click image for larger version.
ID:	247803Click image for larger version.
    Slidell, LA
    4,738
    That is a very neat piece. Where did you find that?
    HondaRidr's Avatar
    Salt Lake
    343
    super cool!!
    Sent from my SM-G930T using Tapatalk
    Oct 2006
    Wapakoneta
    815
    Nice. Is that the NOS one that Mario was selling? Very cool piece.
    Jul 2012
    Seattle, Washington
    1,543
    Lightbulb
    So that’s where Barn got the idea of mounting the radiator on the 1st Gen T3?
    Carthage NY 250r rules
    2,355
    This is a cool piece.Iv only seen a few of these pop up for sale.I have the aircooled version.I had thoughts of getting a fl 350 odyssey liquid cooled head and putting it on my 300r.
    250r rules
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by 3 Wheel Drive View Post
    But ours has a headlight...at least until you crash!
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR AND THE ONLY PERSON ON 3WW WITHOUT AN EDIT BUTTON OR A STAR
    Mexico
    9,020
    I remember seeing a write up on that head when I was about 14 years old and thinking that I could somehow incorporate something like it to my YZ 80 by soldering sheet metal around my air cooled head and plumbing it up to a old heater core that my dad had in the garage that probably had a leak.
    I now realize the result would have been an otherwise perfectly good YZ 80 being sold to a scrapyard.
    That’s the same system one of the Franks Rotax trikes used, but I don’t know if that was Frank’s design, or if Rotax built that head.
    Arizona
    843
    It showed up on ebay a few weeks ago--see xrider's comment about Mario. It was quite a bit of coin but I figured I'd never see another NOS DG water cooled head again, so I bit the bullet. I did the same thing with the Westcoast swingarm, which you never see for the 2nd generation. I bought it 4 years before I bought the machine. I knew I'd get a 2nd generation R someday, so I snagged it on ebay when I had the chance.
    Arizona
    843
    Quote Originally Posted by atc300r View Post
    Here's a water cooled head for the FL 250 and it seems like I've seen them for 350's too (see link). It looks like there might be fitment issues with the bolt pattern and combustion dome (for a 300), but it looks like a good starting point for a machinist willing to make some modifications or start from scratch.
    https://www.ebay.com/itm/HONDA-ODYSS...1Yq49y&vxp=mtr
    Sulphur Springs,Texas
    1,005
    That is very cool! I haven't seen that before , thanks for sharing the sweet pictures!
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    2,355
    The 350 odyssey has the same seven bolt pattern as the 300r.
    250r rules
    Arizona
    843
    Yeah, but I don't think it would be a direct bolt on. What about the combustion camber? I'm thinking issues like diameter and dome volume would create problems.
    Arizona
    843
    I finally got to take the 84 out this weekend and test the DG water cooled head. Damn, this thing hauls the mail--I'm still grinning from ear to ear. Compared to the DG gold head, it revs out a lot harder. I'm not sure what explains it. The next time I have it apart I'm going to compare the domes. It could just be the cooler engine temps. With the gold head I had to run higher octane (97) to prevent detonation, and the water cooled head is running stronger on 91 octane pump gas, with no sign of heat fade. Somewhere on 3WW Mike Coe said his 2nd generation R with the water cooled head was one of his fastest machines. I believe it. If you find one for sale snag it, you won't be disappointed. They occasionally show up on ebay. I'm also thinking about making parts for a few machines. I might trying reproducing it.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by christph View Post
    Depending on how your gasoline is formulated over there, it is quite possible that at least part of the difference is due to the gas itself, because, in the US at least, it used to be made so the higher the octane rating it had, the slower it burned, and this slower burning can reduce hp. Fuels are very complicate and I don't know nearly as much about them as I do about O I L!
    Of course, it there is a difference in the volume of the head, the power will also be different because the compression will be different.
