The 70's get addicting. They are getting very expensive to buy complete. There is a lot of engine options to replace the original. There is a lot of Honda "clones" of that engine that will bolt right in with little or no modification. The whole china quad market helped with that. I have direct bolted up to a 110cc engines into them. Most of the frames are bent along the back bone, but are super easy to fix with a bottle jack. The gas tanks are mostly all junk because of rust, but there are plastic ones available but Ive only seen red ones. You are lucky to have the rear fenders as the older 2 piece ones are hard to find.
If that recoil starter fits and is functional take good care of it. It seems to be the number one thing that is missing on all the 70's I see and can be hard and pricey to replace.
That 70 will be worth quite a bit more than the Kawasaki when fixed up.
YAMAHA 450 HYBRID
85 350X- RED
85 350x -BLACK
86 350x-WHITE (with Goki)
85 250r
83 atc 70
84 atc 70
84 atc 110
09 yfz 450
2006 Arctic Cat Prowler
RZR XP 900
