Which year/model ATC parts fit my 1984 200M
As I scour ebay, I notice many sellers list parts for my 1984 200M that also fit 84-85 200S, Big Red, etc.
Is it safe to say that most parts from a 84 200S would also fit a 84 200M? Are there any other years/models with interchangable parts for 84 200M?
Thanks!
A lot of the engine parts will interchange since it's basically the same engine. Body parts, on the other hand, are a different story.
a lot of parts will interchange between a 200m and 200s but not everything. Engine parts will mostly swap there are some slight differences between motors mostly in the recoil and coil side of the motors are different. body and frame parts do not swap. Now that being said everything from an 82-83 200e big red is a direct swap bar the front suspension. same thing can be said about an 84 200es big red but the rear end parts are completely different due to the shaft drive. now my 200m is a hodge podge of after market, and stock parts coming from probably all the different 200 series bikes and my flywheel is from a trx 125. I also have retrofitted parts from modern Honda to fit my bike. your best resource is to look up the exact part on a site such as partizilla and check which bikes that that parts fit.
//ArrowChat Integreation Code
