Results 1 to 13 of 13
Thread: Rear Rim and Tire Recommendation for 85 Big Red
    Jun 2003
    South of Rochester, NY
    3,470
    Tire-d of dealing with old Big Red rims and tires that don't hold air... Any one have a good recommendation for replacement rim and/or tires?? Please and Thank you.... Hondaline OUT....
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Mar 2008
    Tug Hill
    1,282
    that has one offset rim for the brake drum correct? I had spider-tracs on my 86 big red and I loved them. When I first got it it had those tires I forget their name but they look kinda like old Humvee tires with squiggly lines in the center and side lugs. they sucked but were thick and held air lol.
    Mar 2008
    Tug Hill
    1,282
    the first set I had looked kinda like this pattern. they worked ok but didn't clean out like you think they wouldClick image for larger version.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    299
    Quote Originally Posted by lndy650 View Post
    I think those were Dick Cepek Buckshot mudders. I had a set on my 250sx. Good for sliding.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    299
    For a 2nd gen big red I would try to find some Honda 12 inch rims for an sra foreman 450 or something like that. Then I really like the GBC dirt commander but they are 8 ply so you would have to run them with like 2 psi to not ride rough. GBC has a 25x12 inch in a 8 and 10 inch wide tire.
    Sep 2017
    Cadogan AB Canada
    52
    I just have the stock rims but I have carlisle strykers on my trike and they are holding air great with good treads, they even hold air on the old beat up front rim that was totally messed.
    Depends on what you do with the machine but in the rocky New Hampshire mountains you'd be hard pressed to beat the Cheng Shin knobbie. Great shock absoption as well as traction in mud and they're great in the snow.
    Dec 2012
    812
    I ended up buying an ITP steel wheel to replace one of my stock rims that was bashed to crap on one of my 250ES'. The ITP rim is garbage. The tire won't stay seated unless it's over-inflated!
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Jun 2003
    3,470
    Quote Originally Posted by Big G View Post
    Good to know... I would like to replace the OEM steel rim. I have a set of vintage aluminum rims (stamped 3-10-90) BUT... they are a 8" wide, 10" dia. rim. Stock is 9"wide, 9" dia. rim. If stock tire is 25x12-9, should I run a 25X11-10 on those aluminum rims? I know some aftermarket tires were 25x13-9 or 25-12.5-9 and work on the OEM rim. Figure if the rims are an inch narrower, I should get a tire an inch narrower?
    Bruce
    Jun 2003
    3,470
    Looking at this tire for the rear of my Big Red on the aluminum NOS G.B.C. rims (large bell 4-110 8" by 10" dia 3+5 off set Korea manu. date 3-10-90) I figure rim is an inch narrower, so go an inch narrower on tire???
    I think they sell a 25x12-10 too. What do you all think???
    Bruce
    Jun 2003
    3,470
    Want to pull the trigger on this.... I see there is one application where a Polaris uses a 10x8 rim with a 25x12-10 tire... the rest run a 25x11-10 for a rear tire with that 10x8 rim. What do you/anyone Bueller? think???
    Austin, Massachusetts
    1,591
    Rough ride on that buffalo. A large part of the suspension of that machine is in the tire. If you're gonna ride it hard, you should look into a 2-ply tire. Also, you're gonna have a tough time sliding those things.
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    Jun 2003
    3,470
    Didn't think about that part... Looking for traction for snow plowing. Low speed work machine, putt around with the kids.... I was thinking 6 ply less flats/longer lasting. Though... I got the 350X and 250R for suspension. I'm curious about which width to order.
