https://youtu.be/LUftRXfItHk
Video of meter connected to ignition coil wires while cranking.
That doesn't appear correct. I have only used a tester light but the light was lit the whole time but fluctuating between dim and bright. I would have expected to see the meter hover between low volts and 12v. It appeared you may have had 12v but very seldom.
Kind of looks like symptoms from a bad ground or could be bad cdi. I would double check all grounds and make sure connectors are good and ground ohms out at 0. Do you know anyone with same bike you could swap cdi with?
I think the crankshaft that runs the stator breaks by the stator it happens
https://youtu.be/3YDjyYc2ZKk Exciter coil ohms measured 317.3
Pulse generator ohms measured 330.9
Haven’t checked voltage on the pulse generator yet, will check as soon as I get a chance.
If you can pm me your name and address I can pull my Cdi off my 85 250sx....it's the single connector not the double connector type....and send it to ya to try if you could send it back after you try it. That way your not throwing money at it not knowing if that's the problem.
Video of meter reading on pulse generator blue/yellow wire and green/white wire.
That would be awesome. I’ll pm you.
ya looks like its gotta be the cdi the pulse gen is definitely good
I'm just wondering, the values given for the resistance measurement give one for ND and one for MITUBA (have no idea what this stands for), which value should I be comparing to?
ok so the exciter coil tested good, the pulse coil tested good, good wire and cap, new coil, and cdi off running 250sx. im thinking it has to be a bad wire somewhere. with this new coil what is the coil reading from the cdi plug is it still over spec at .4 or is it in spec now?
i was thinkin it might be possible theres bad wiring if the reading is still high at the cdi plug but normal at the coil
