Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 31 to 45 of 90
Thread: 1986 200x saga
  1. #31
    6bt's Avatar
    6bt is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2017
    near Syracuse NY
    318
    Or even another damaged frame with a good cradle.
    Sent from my XT1254 using Tapatalk
  2. #32
    AMK's Avatar
    AMK is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2017
    Shelby, OH
    181
    Yeah, guys, it just a little discouraging. I've seen frames on eBay around the two to three hundred dollar range.
    I am going to drop back 10 on this one but I'm not ready to punt yet.
    Alan
    1985 350x
    1984 200es Big Red
    1985 200s (little red)
    1986 200x saga
    2) 1985 350x projects
    And a slew of others to hold my attention
  3. #33
    6bt's Avatar
    Jan 2017
    near Syracuse NY
    318
    Quote Originally Posted by AMK View Post
    I ran into a similar issue with my cr500. A little rot in the cradle. I did find a street legal Oregon frame though
  4. #34
    Connecticut
    1,605
    Would you need to buy a titled frame or just a solid one?
  5. #35
    AMK's Avatar
    Jul 2017
    Shelby, OH
    181
    Quote Originally Posted by sledcrazyinCT View Post
    Just a solid one. As long as it doesn't come up stolen. I can get a regristration made as a rebuild.
    The only thing Ohio needs is a registration to operate on public lands or to drive alongside the roads.
    At least it was that way when I did it in '93.
    Alan
    1985 350x
    1984 200es Big Red
    1986 200x saga
  6. #36
    AMK's Avatar
    Jul 2017
    Shelby, OH
    181
    Dirtcrasher, did you receive my pm?
    I think I'm going to get the motor buttoned up at least and see what develops on the frame.
    Alan
    1985 350x
    1984 200es Big Red
    1986 200x saga
  7. #37
    AMK's Avatar
    Jul 2017
    Shelby, OH
    181
    So I couldn't let it go. I hate scrapping anything on these machines.
    I know earlier in this thread I was slamming "weldors" but now I are one.
    I decided since the frame was junk I'd see how junky it was. So I cut it until I got to good metal.
    Alan
    1985 350x
    1984 200es Big Red
    1986 200x saga
  8. #38
    6bt's Avatar
    Jan 2017
    near Syracuse NY
    318
    Why not? You could probably buy the same od tubing, same wall thickness, and cut out what you need. Weld it in and your good to go. Another 200x frame saved.
  9. #39
    AMK's Avatar
    Jul 2017
    Shelby, OH
    181
    I made some 3/4 wide by 1/4 inserts and fitted them to the holes.
ID:	249885Click image for larger version.
    And a coworker and I welded them in.
ID:	249887Click image for larger version.
    Polished them up and ready for primer and paint.
ID:	249889Click image for larger version.
    I think this is going to keep me on track with this project.
    Alan
    1985 350x
    1984 200es Big Red
    1986 200x saga
  10. #40
    6bt's Avatar
    Jan 2017
    near Syracuse NY
    318
    There ya go...didn't realize they were square tubing. 200x is next for me probably
  11. #41
    AMK's Avatar
    Jul 2017
    Shelby, OH
    181
    Quote Originally Posted by 6bt View Post
    I've had 200x's in the day and they are GREAT machines. I can tell you though, buy a good one.
    I've got a lot of money tied up in this one but I really want to see it through. Labor of love for sure.
    Only the 2nd gen are square.
    Alan
    1985 350x
    1984 200es Big Red
    1986 200x saga
  12. #42
    Las Vegas, NV.
    2,452
    Yes, but you're welding it to fix it properly. The welding done previously, was because someone was too lazy to fix it the right way the first time.
    Nice job saving the frame. You didn't grind away all of the weld you just laid down did you? It kind of looks that way in the pics.
  13. #43
    AMK's Avatar
    Jul 2017
    Shelby, OH
    181
    Nice job saving the frame. You didn't grind away all of the weld you just put on did you? It kind of looks that way in the pics.
    No, that's why I went with 1/4" thick stock. I wanted good penetration.
    Don't say it!
    Alan
    1985 350x
    1984 200es Big Red
    1986 200x saga
  14. #44
    May 2015
    San Diego, CA
    1,743
    Nice work on the frame.
    It's like 88 degrees here........what's that white stuff on the ground?
  15. #45
    6bt's Avatar
    Jan 2017
    near Syracuse NY
    318
    That's tire lubricant, helps the trikes slide better. Goes away when it gets warm though haha.
