Results 1 to 15 of 15
Thread: coming soon to tri-z owners far and near
    glendive, montana
    1,822
ID:	250511Click image for larger version.
ID:	250512Click image for larger version.
    this will be a single gasket to replace the current dual exhaust gasket setup. currently I only have two made untested for oem expansion chambers. DG style is in fabrication as well. I will start selling them after I am able to test them out. Brandon
    Arizona
    844
    Nice. It's so annoying to have an exhaust that spits oil everywhere.
    glendive, montana
    1,822
    I do still currently sell the replacement discontinued gasket, but I am desiring to eliminate yamaha's defunct dual gasket design
    brandonlowe2's Avatar
    brandonlowe2 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2016
    Georgia
    412
    I’m in for one of the DG style when it’s done
    1983 Selvy 300R - Check out the Build Thread
    1985/86 Tri-Z - Build Thread Coming Soon
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    Youtube Channel "Lowe Off Road"
    - Brandon
    Sep 2006
    Northwest Indiana
    1,893
    Great work and definitely needed!
    glendive, montana
    1,822
    who want's to help me try them out for half the cost of what I will be charging for them when they are tried and tested. this is for stock exhaust and will eliminate any other gasket. pm me for details.
    glendive, montana
    1,822
    offer was accepted and one of the prototypes is in the mail for testing, the other I kept and will test myself when I am able to.
    glendive, montana
    1,822
    Update have installed the second prototype in my Z today was a tight fit into the pipe. Had to tap it down the last 1/8 inch because of the o-ring which creates a seal. Is a nice perfect fit without the o-ring on there so I know it seals on stock pipe. Started up with a perfect seal on Tuesday I will be utilizing the 60* weather and doing a little riding for final results. After that if all is well these will become available for sale for stock pipes only at the moment as I have not received enough measurements from dg pipes owners to determine consistency.
    9,010
    Hey, sorry for the delay on the report.
    I will stuff mine into two DG pipes tomorrow if I can and post I.D. and depth.
    The part looks great! Love the O-ring. My only doubt at a glance is the flat rubber gasket.
    Wondering if it will hold up over time and if a crush washer might be more durable in the long run.
    It sucks to get old
    glendive, montana
    1,822
    El Camexican yours is for a stock pipe setup not dg, when I do the dg's they will have 2 o-rings instead of the single as there is more depth from their collar length unless you have the short dg collared pipes. I know there is 2 dg versions out there. the flat rubber gasket works perfect as a seal to the exhaust port, is the same type of rubber as the o-ring and should handle up to 500*f of heat which is more than our pipes get and is supposed to be able to withstand fuels as well. with this design those two should be the only items that will need to be replaced. which if all is right with this I will stock them for quick replacements. Brandon
    glendive, montana
    1,822
    Update took my Z out for a three hour ride and all o-rings held up with no leaking at all. I am going to make these available in the store around Monday. I currently only have enough material to make 8 more but after those 8 sell I will purchase much more material and o-rings to make a large group of them. They are currently only available for stock pipes but if enough people get me dimensions on the dg collar I will be able to tell whether dg kept their pipes uniform to stock and if so will make these dg compliant as well. Brandon
    N.E. Ohio
    2,005
    I'm in for the DG units 2 new style but will take 1 old stock style to get rid of them. PM me if ya could include address and contact info to send payment. Thanks
    9,010
    Here are the DG dimensions I have of long and short spigot styles.
    Short: Depth is .928” to .940” and diameter is 2.27” to 2.30”
    Long: Depth is 1.38” to 1.43” and diameter is 2.27” to 2.28”
    Let me know if you need any clarification.
    It sucks to get old
    glendive, montana
    1,822
    the 2.27 is the I.D. correct. if so I can make that work with my current o-ring setup. the short DG style will work with my stock gasket and I can fit in a second 0-ring with the long DG style to help. have you tried the gasket yet and if so what are your results, mine were great with a stock expansion chamber. I just haven't got a chance to make more gaskets yet as the weather cleared up and I have had people bringing me machines to work on already along with my fulltime job, but they are coming soon to the store. I will make one long DG style and offer it soon, but the other seven I have material for will be oem and short DG pipes only.
    glendive, montana
    1,822
    I just made a dg long style gasket with the measurements I was supplied by a few people so enjoy the eye candy Click image for larger version.
