250sx tire wheel set up help needed
How痴 it going I知 in the process of restoring my Honda 250sx. I understand a 110ラ4 10x5 3+2 wheel with a 23ラ7ラ10 tire is a popular front set up to achieve a skinny front end. So I was able to find a DWT wheel with matching specs also a Kendra bear claw tire with matching specs, However I知 not sure on specs for the rear wheels to clear the brake drum. wheels must be matching brands front and rear and also only and a polished finish. Any help is appreciated.
I put 1.5" wheel spacers on the back of my 85 250SX so I could run a pair of 200X rims on there. You also may be able to get away with running 9" diameter rims instead of the factory 8".
Here's a picture of mine with the spacers and the 200X rims.
//ArrowChat Integreation Code
