So last night a friend of mine came over and was helping me wrench on the 200x a little bit. He set the throttle needle to middle position however today when I rode it, it high revs in 4th and 5th gear. If you shift into 4th and hold the throttle halfway it's okay but when you crack the throttle it just goes high and doesn't really take off like it should, if you shift into 5th it does the same thing. Is it getting to much gas when I crack the throttle in these gears. Could him adjusting the needle have caused this issue?
