Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: Pulse generator help!!!!
    Nov 2015
    Davenport iowa
    1,144
    Quote Originally Posted by Dgonzo View Post
    So the DR8ES-L is the incorrect plug for my 1984 110?
    Do not use the L plug, the DR8HS is correct
    Mar 2018
    Tulare, California
    21
    So I’ve tested my kill switch on it. I have one lead on the black wire and the other lead on the green wire, when the switch is in the off mode I have 0.2 ohms. When the switch is in the run position I have 0. This sound correct? I have tested both the black and green wires all the way back to the cdi plug and I consistently get the same readings. From what it looks like I can count the kill switch out as a bad component.
    One lead on ground the other on the spark plug boot- 2.7 ohs
    Mar 2018
    Tulare, California
    21
    Also how can I check my primary coil to make sure it is working order?
    Apr 2012
    USA
    4,114
    Yea 0.2 ohms = short, aka good connection. Inf or no connection is normal for the run operation. Just to note, most multimeters have a buzzer option for the ohm tests, exact numbers don't hurt, but for just testing if there's a connection or not, the buzzer works well for quicker testing. On my multimeter, it reads 0.F for inf resistance (aka no connection), I've seen some put a 1 at the far left spot. The buzzer option normally has kind of like a sound icon. On mine I put it to the ohms setting then press the mode select button to switch it to the buzzer, other meters it's right near the ohm settings. Touching the probes together shows what connection looks like, and apart shows no connection, never hurts to test before using it on something.
    Here's some screen shots from a Honda ATC125M service manual, it illustrates the process better than I can explain. The numbers are probably off from what you should have, but hard to say with the other manual having the wrong spark plug info, who knows what else is wrong.
    Feb 2016
    Stellenbosch, South Africa
    180
    My suggestion is similar as to the atc110, but there are a lot of wires, so you'd want to narrow down the search. Assuming your machine is a 1985 since that's the most common (86-87 should be similar anyway)
    Disconnect handle bar switch and test black/white wire to green with kill switch to on, should be no connection. Test the same wires on the harness side with ignition switch to on, again should be no connection. If there is a connection, the CDI is being signaled to not spark and you'll need to test the ignition switch or kill switch directly and replace as needed (unlikely).
    Next I'd pull the CDI out for probing. Green wire to clean engine ground, or the frame ground location should have solid connection. Grounds are pretty critical so never hurts to validate it's good. All solid green wires should be the same connection at any point in the harness.
    The big red has a neutral and reverse safety switches. With a battery and key on and machine in neutral, the neutral light should light up. If it does not, either there's a poor connection, bad safety switch, or burnt bulb. Both safety switches connect to ground with enabled (aka when in neutral, neutral switch connects to engine ground). I suspect this is the likely cause since it's near the bottom of the engine under the little metal cover. I sell replacement sub harnesses for them using plain bullet connectors (no rubber housing around them). If one of the switches test bad, you can buy them from Honda yet. I've had a machine with shifting problems also cause the no spark problem and no neutral light, getting it into neutral gear after disassembly fixed the ignition problem.
    Ok, if all tests good by this point then I'm thinking a bad wire or CDI. CDI is easiest at this point if you have a known working one, or can borrow one. I kind of hate to suggest buying a CDI since they can be expensive. Connection quality can play a large factor and could make a good cdi appear bad.
    Probe time for the rest of the CDI pins....
    Green we tested already
    Black/Yellow goes to the coil
    Black/Red goes to the alternator area on the engine (bullet connector)
    Blue/Yellow & Green/White goes to the pulse generator @ the same general location as the alternator connectors (3 pin connector)
    Black/white goes to ignition switch and kill switch, generally when the wire fails, there won't be a connection, which would fail in the can't stop the engine running style.
    If everything tests good, might have to go over the individual component tests again to be sure they are in fact good. My bet is the neutral safety switch wire though, most of the machines I've seen had pretty corroded up wires, or the connectors were very loose and made poor connection.
    The rest of the wires are for charging, starting, lights, etc and shouldn't effect the ignition system.
    I have a 250es service manual if you need any specs.
    I almost should build a website with step by step troubleshooting steps and common problems lol.
    Thanx buddy, I can see you have gone through the same thing haha, I have checked everything as you described above and everything checks out 100% everything is in spec, but still no spark .... i am going to have to start with each wire until I find the culprit.
    1983 Honda ATC250R
    1983 Honda ATC200E BIG RED (sold)
    1984 Honda ATC200E BIG RED
    1984 Honda ATC200X (sold)
    1985 Honda ATC70 x 2
    1985 Honda ATC250ES BIG RED
    1988 Honda ATC250ES BIG RED
    1995 Honda Frankentrike 50cc 2-stroke
    2001 Honda TRX90
    2004 Honda TRX300EX (sold)
    2008 Honda TRX250TM
    1976 Suzuki RV90M (sold)
    1967 Vespa Primavera 125
    1958 Massey Ferguson 35
    Apr 2012
    USA
    4,114
    Ironically, the worst I've had with a 250es/sx was one stuck in gear. I've poked around wire diagrams and such enough and seen other member's issues to have a bit of a list of common things to check. Probably wouldn't be a bad idea to make a new thread if it isn't clear what is wrong to keep things separated a bit from the original topic. Hopefully it's an easy fix and can be spotted once you find which wire is causing the problem.
    Another thing to look for are tiny little holes in wires from people trying to probe wires to test them. Over here in the US it's fairly common to find, and 2-3 years later the wire that was poked is completely junk and has to have the section replaced because the person that probed the wire didn't seal it in any way. I got a truck that way and the fuel pump wire was poked where it would run the pump, but not well enough to start the engine, fixed the wire and it ran fine.
    Good luck on the wire hunt.
    Mar 2018
    Tulare, California
    21
    Well I finally got this thing running!!!!!!! Turns out the “working” magneto and coils I bought on eBay did not work at all. I bought a low hour motor on offer up and swapped out that stuff and it fired right up! One pull and she runs good! I’ll be changing the oil and tightening a few loose ends and it will be good to go!
    May 2009
    S.E. Michigan
    1,250
    Guys,
    The -L simply means it is a half-heat range version. It is a heat range 8.5, but they designate it 8-L.
    https://www.sparkplugs.com/Data/uplo...ug_Chart_1.jpg
    Check out the data on the plugs right on NGK's website. The physical dimensions are identical.
    https://www.ngk.com/product.aspx?zpid=9747
    https://www.ngk.com/product.aspx?zpid=9746
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Nov 2015
    Davenport iowa
    1,144
