So after putting it on the stock carb doesn't seem to like the gravity feed. It keeps cutting out on top end. I dropped a few jets didn't fix it. Any ideas
Sent from my XT1635-01 using Tapatalk
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
86 tri z powervalved
85 BIG red
18 rmz250
87 lt80
19 ttr110
How it looks.
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
That makes no sense. Is your gravity tank fuel line going straight from the new tank into the carb unrestricted?
The reason I ask is that since the Z had a fuel pump, I assume it also had a built-in pressure regulator somewhere in the fuel delivery system and if you try to run a gravity feed thru a pressure regulator, the regulator would just cut off the flow since it's not under constant pressure.
That's all I got.
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
Just run it straight with out the shut off and see if it changes how it runs on topend
I agree with big specht.
I'll try it I'll get back at you guys.
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
Well runs awesome now! Was the stupid shut off valve. Where can I get a high flowing valve from?
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
Metal with red plastic handle. I too had a lawn mower type shut off on my Tecate,,, mainly to test tank out.
Sevral different types on ebay using the search wording
" atv fuel shut off valve"
Not sure if you need angle, straight line,,, barb both ends (probably)
I use Motion Pros sometimes and Pingel if I'm feelin rich
Edit: the Motion Pros look just like the one in Swineharts top pic
Now it's loading up on bottom end wtf
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
Try new plug first
