Took off the recoil cover and it was a little wet but not soaked. I hosed it down with starting fluid and blew it out with air. Still no luck. Any ideas? Did I fry something? : Should I use this as an excuse to throw it away and get a 140cc?
How big was that puddle? LOL
Possible it may have got wet in the kill switch(?)
'83 200X
Try a new plug. Sometimes the porcelain cracks when they're hot and get wet.
Had this happen on a 400 SBC in a Blazer once when wheeling through mud. Took a long time to figure out the plug was bad.
Tried the new plug and still no love. Time to find a repair manual and bring out the ohm meter. =/
Simple things first. Did you unscrew the spark plug boot to see how the connection is? Pull all your connections apart and blow them dry just to be safe. It ran before the puddle.
Trikes
1970/71 US 90 (Aquarius Blue)
1972/73 US 90 Green
1977 ATC 90 w/83 110 motor (Fugly)
1982 ATC 70
1983 ATC 70 (Ladybug)
1973 ATC 70
TF 2015
Other
1983 Honda Z50
1978 Honda XL75
Next time build a snorkel before you go submariner on the old 70.
I suspect the issue is that you drove a puddle jumper through a puddle rather than well, you know... jumping it.
It sucks to get old
New points and condenser , only OEM no china junk .
I agree with Mike, when I read your posting a couple days ago thought did you remove the flywheel/stator to clean or raise with starting fluid, which isn't a solvent cleaner and won't remove the rust / corrosion between the points contacts. Clean the points faces with a thin file and piece of cardboard like a match cover, old timer's trick.
"HJ"
’84 YT60
’89 TRX250R (stock )
’90 LT500 Quadzilla
'83 200X
I got the flywheel off and it looks like there should be something on the crank or flywheel that opens and closes the points? Still has the felt that cleans it. Anyone have a picture of one in working condition?
The flywheel or stator has an eccentric cam lob built into the center hub which opens and closes the points. Points need to be set / adjusted to open at the "F" flywheel timing mark to run. I've added a pic of a modified / machined flywheel a fellow member "KASEY" posted on the site many years back. Setting and or adjusting the points is difficult for even the best of us.
"HJ"
’84 YT60
’90 LT500 Quadzilla
