Both, plus in my reading on this cat motor I definitely wanted a fresh oil change before a 1.5 hr drive. The 3126 tends to blow the high pressure oil lines
Nice rig! A hot pressure washer/steam cleaner would take a good amount of that crusty New England road salt off your frame. So sad the caustic they coat the roads with these days.....kills so many vehicles. Municipal plow truck frames disintegrate in a few years yet they still spread this crap by the ton.
Now that you got it in your garage, please keep up updated with your progress getting it back on the road
Ya I wanted to steam it first but I needed it into the shop to get brakes going
Once I have brakes I will pull it out and spray
Whatever undercoat that was used is coming off in huge chunks, I was screwdriver scraping a ton of crap off. I will do that for a bit, wash and scrape then get some oil or boshield on it and just keep up with it
Plasticos you are a damn animal, lol. You never disappoint. I've dealt with scaly truck frames from my very first truck (66 F250) and continue to deal with it to this day on my 99 F350. I bang the heavy scale off with a , scrape the stuff that is sticky, then I use the pneumatic needle scaler and sometime the wire wheel, but the wire wheel usually on the stuff that's sticky or intact paint. I brush on POR 15, it's best on rusty metal. It really sinks into metal that has some porosity from oxidization, so you don't have to strip the frame bare. It will never look like a show frame, rusty stuff will bleed out of it, but the paint literally becomes one with the metal. Here I am giving you a tutorial, you're probably already familiar. I plan to hit my frame a second time this year and it should be near forever sealed at that point I would imagine.
I'm wondering if you're technically supposed to have a hoisting license for that crane. I think you're in RI? I don't know if RI requires a hoisting license. I'd have to guess Mass would require one for that. I used to run a Stetco catch basin cleaner that had a little crane on it with a hydraulic clam shell bucket on a wire rope. It was the tits. I got really proficient with it and it became an extension of my own body, I could do anything with it. The trick was to follow the bucket with the crane, it was fun.
Good question fabio, I dunno. I will check into it
Very familiar with por15 and love the product, just not sure I want to tackle the whole underneath of this beast! I guess I could do little sections but that rack body sits about 2ft higher than frame rails so the reach to the crossmembers would be a pita. Also there is so much corrosion I am just dying to coat everything! I am gonna try some boshield (esp as I can spray it), I have had good luck with it. If I see it isn’t enough I will start hitting sections w por15 or pull the body and do it right
Update looks like there is a crane license for delivery truck. Yea, more money to the state
Quite a few of the road maintenance companies spray their equipment with Krown rust proofing which is an oil based product that actually creeps as it works. I've been quoted some very high numbers in savings on corrosion/electrical repairs by using this stuff. It's not one and done and needs to be reapplied every couple of seasons based on conditions of use. I just had my 06 Ram Mega Cab done after I had the regular dodge fender well rot out repaired which ran around $160.00 Cdn. It's superior to RustCheck IMO.
Trikes
1970/71 US 90 (Aquarius Blue)
1972/73 US 90 Green
1977 ATC 90 w/83 110 motor (Fugly)
1982 ATC 70
1983 ATC 70 (Ladybug)
1973 ATC 70
TF 2015
Other
1983 Honda Z50
1978 Honda XL75
I wonder how many "friends" will come out of the wood work wanting you to lift/haul things for them now? Same thing happens when you buy a car hauler, you'll find out quickly, lol.
Trikes
1972/73 US 90 Green
1982 ATC 70
1973 ATC 70
TF 2015
Other
1983 Honda Z50
1978 Honda XL75
We will see! As my wife rolled it into an llc, she will keep an eye on when that truck leaves for “jobs!”
Truck looks like a handy thing. When I was getting started in equipment I had a GMC 70 with a roll back bed. It sure was handy with a winch to retrieve dead projects.
Sent from my XT1254 using Tapatalk
