Originally Posted by
wb225dx
YTM225dx ran fine Tuesday....went to ride yesterday and wouldn't start. Plugged my spark tester inline and there is barely enough juice to light the bulb...not even enough to show a spark on a grounded plug. It was wet and raining when I parked it. Doesn't matter if its battery crank or hand pull, still super weak spark. I took all connections apart and they looked good. Could it be a bad ground on the coil from the moisture? Where would you start looking? Stator and or CDI....maybe the voltage regulator?
