Results 1 to 15 of 15
Thread: Tie Down Straps and their storage
    Jan 2018
    US
    24
    What do you guys use to strap down your wheelers and what tinsel strength are they. I've been using rope on mine, but would like to upgrade to a proper securing device. How do you store them when not in use?
    Nov 2015
    Davenport iowa
    1,144
    Thumbs up
    Ratcheting straps
    I also have some of these and they work great . Bigger than the typical ratchet straps but sure are nice..
    Cold Lake, Alberta, Canada
    3,001
    Standard stuff, keep them dry, keep them clean and be mindful of their tensile strength. I roll mine up after I fully extend them after use and store them that way. A good old Army surplus ammo can is watertight, durable and cheap to purchase to hold them in one spot. One trick is to give the long end one twist when securing the strap as it runs along a flat surface to keep the strap from vibrating badly at highway speed; along the sides only! I prefer to use straps that are at least 1" in width.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    1978 Honda XL75
    9,011
    Just keep in mind that straps have a safe working limit and a break strength. Typically the safe working limit is between 1/3 and 1/2 of the advertised break strength.
    If you opt for the cam lock type be sure to tie a knot in front of the cams as they can slip and loosen unless they are high quality which is difficult to find these days.
    It sucks to get old
    Jan 2018
    US
    24
    That is great advise. Here is a link to different tensile strengths of poly strap material. I have a lot of homework ahead of me before I make a decision on what straps will be best for my 125m.
    https://www.strappingtoolsandparts.c...-kb-16112.html
    9,011
    Quote Originally Posted by Bob Smith View Post
    Umm that's a different kind of strapping that you need Robert. Try this site http://www.uscargocontrol.com/Ratchet-Straps-Tie-Downs
    It sucks to get old
    The Open Road
    4,729
    May 2015
    San Diego, CA
    1,743
    Your over thinking it.
    I've used the cheapest Walmart/Harbor Frieght/K-Mart straps around on my 1000lb Goldwing, quads, bikes, etc. I shipped classic Bultacos to collectors in Italy with cheap pull straps.....never a fail.
    Use the 20% coupon at harbor frieght.
    N.E. Ohio
    2,005
    If you go riding with my buddies... I recommend marking them some where to id them. Never fails everyone has the same straps and often get swapped out. Leaving you with the spent bent or worn one. They somehow get long barrow too, always nice to grab one back off your buds hook in the garage. Well after you share some of his cold beverage collection.
    The Open Road
    4,729
    Nice truck!!
    TTown, Alabama, United States
    845
    I use these here. The 2" ones with the J hook. Perfect for my needs, hauling wheelers, hauling lumber, use as a tow strap etc, etc...more strap than you'll ever need for an atv.
    https://www.spanset.com/us_en/products/loadgard2
    Suicide Hill Survivor
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    Jul 2012
    Seattle, Washington
    1,544
    Hi Barn!
    Sabula,IA
    618
    I've been using Ancra for nearly 30 years. They never slip or loosen. You really don't need the extra hassle of ratchet straps. You can pull cam straps surprisingly tight.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
