Results 46 to 60 of 60
Thread: Polished Tri-Z Engine
  1. #46
    7,839
    Quote Originally Posted by 3 Wheel Drive View Post
    Looking good! Did you go OCD on polishing your carb too?
    There you go.
  2. #47
    7,839
    Quote Originally Posted by yamaha_ripper98 View Post
    Any plans to do a golden/copper color inlay on the clutch covers Yamaha logo to match the kicker and studs/nuts&bolts?
    Thanks for the suggestion!
  3. #48
    Mar 2013
    Baldwin, Wi
    600
    Tonight was spent installing the Yeager Performance sourced billet clutch.
    Attachment 257511
    Attachment 257512
    Attachment 257513
    Attachment 257514
    Attachment 257515
    Attachment 257516
    Attachment 257517
    That basket will rub on the inside of the clutch cover. There is a casting ridge that you need to shave down a tiny bit. It might not rub on assembly or at idle but with just a bit of RPM it expands and rubs.
    85 Tri-z Basket Case
  4. #49
    7,839
    Quote Originally Posted by NeverLift View Post
    I've heard that. Even the stockers seem to rub a little on some covers.
  5. #50
    7,839
    All done
    LA Sleeve with 68mm bore, Wossner YZ piston, boost port added, port matched, exhaust port raised 1mm, head and cylinder decked and cut, squish set to .041”, rebuilt 39mm Keihin with small fuel valve orifice for use with fuel pump, new oem KOYO bearings throughout, Talon billet clutch basket, Sprock intake boot and stainless steel water pump, V-Force reeds and a custom case saver from a member.
    Just add ignition and go!!!
  6. #51
    Las Vegas, NV.
    2,172
    That's a pretty engine!
  7. #52
    Oct 2006
    Wapakoneta
    809
    Beautiful work
  8. #53
    Jul 2018
    TN
    1,006
    Looks great! Wonder if you could do a braided stainless coolant hose? That black sticks out to me. Then again, you won't see it as much once installed.
    That's a LOT of labor.
  9. #54
    Jun 2013
    Oceanside, CA.
    525
    Looking good......another project done too perfection.
    "HJ" Click image for larger version.
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
  10. #55
    7,839
    I have no intention of putting that engine into a frame. When I die you can buy it from my wife (she'll probably give it away to spite my ghost) and put whatever hose you want on it.
  11. #56
    East Bridgewater, MA
    10,066
    My lord Nico! That is a ton of work!
    7,839
    I like to think of it as OCD therapy more so than work. If polishing paid, I'd be happy to do it for a living. My buddy wants to FedEx me his sled tunnel LOL!
    Last edited by El Camexican; 03-16-2019 at 10:09 AM. Reason: Nico Suave Polishing Services, making the world a brighter place to live
  13. #58
    Oct 2005
    uk
    87
    El Camexican.
    think ive said it ......that is 1 sweet looking lump.
    how many hours did the take you,
    just started stripping my cases, and finding to many imperfections in mine, and im only 6 hours into to it.
    ian
  14. #59
    7,839
    Cool! I love me a Tri-Z build! Just finished this a few minutes ago. Same billet internals as the shiny one, but no additional boost port and it has a 68.50mm bore in an LA sleeve.
    I didn’t keep a record, but if I were to add up all the hours spent polishing, finding parts, doing port work, contemplating various things like hardware lengths and assembly it would probably exceed 300 hours, but keep in mind that l’m not doing this for a living, so I have no motivation to cut corners on any detail and I do things like lapping parts, removing casting flash from the internals and tapering oil gallery’s, so that kind of detail makes up a lot of the time.
    Just an FYI if you’re inspecting your cases; take a good look around the area of the cases that house the starter assembly. Half the cases I have purchased have damage in that area, either from being over-rotated, or from being kicked over after sitting for a long period of time causing the retaining spring to corrode to the shaft.
    And make sure to replace that funny looking C shaped spring. When that gets weak it can result in a broken clutch cover. $3.00 VS $300.00
