Results 1 to 4 of 4
Thread: 85 Honda 250sx output shaft issues
    Apr 2018
    Belfast Maine
    4
    New here but not new to 3 wheelers. Thanks for approving my membership. I just bought a 85 250sx apart with new rear fenders and a plastic tank. The output shaft had been removed by the owner before the guy I got it from. It was slid most of the way back in but it doesnít wanna go and I donít wanna force and break something. Do they go in dry or do I need to tear down the block to assemble it properly? The shaft is barely sticking through the gear between the Kickstarter shaft and the trans main shaft. When I apply pressure it turns hard. Iíve had many 200s and 200x apart but nothing shaft drive. Any advice or info much appreciated.
    Howdy's Avatar
    Celina, Ohio
    10,037
    If it has been pulled out you will need to split the motor. That shaft has al sorts of gears, washers, and stuff on it. Not a easy job due to all the parts must be put back on the shaft correctly.
    Howdy
    Quote Originally Posted by chriswhit123 View Post
    New here but not new to 3 wheelers. Thanks for approving my membership. I just bought a 85 250sx apart with new rear fenders and a plastic tank. The output shaft had been removed by the owner before the guy I got it from. It was slid most of the way back in but it doesn’t wanna go and I don’t wanna force and break something. Do they go in dry or do I need to tear down the block to assemble it properly? The shaft is barely sticking through the gear between the Kickstarter shaft and the trans main shaft. When I apply pressure it turns hard. I’ve had many 200s and 200x apart but nothing shaft drive. Any advice or info much appreciated.
    Apr 2018
    Belfast Maine
    4
    Thanks I was thinking that as I’ve done several 80s and 90’s Honda CR’s. I had it about a 1/4 inch from being all the way in. When I split the block last night nothing was floating around. It was the reverse gear bushing wouldn’t align. Just waiting for my gasket kit and then I’ll be riding this baby. Got this machine with new fiberglass rear fenders probably bad for surviving any kind of blows especially where I just wheelie to go over large down trees and it. Has a plastic tank also. Came with lots of spare parts. I was gonna upload pics but my iPhone doesn’t seem to let me
    fabiodriven is online now Aspiring romance novel cover model, and the Official 3WW slayer of thieves and swindlers. Catch me if you can
    East Bridgewater, MA
    9,512
    I approve of you riding technique. When in doubt, throttle it out.
    86 ATC 250SX
