Results 1 to 3 of 3
Thread: Longer shift lever. '83 200X options.
    May 2016
    OH Canada
    1,102
    I have size 12 feet. Shift lever is a bit on the short side than what I would like. I ride with MX boots. Always have a problem upshifting. I have raised the lever up on the splines and is OK. Looking for better.
    I have several routes:
    1. Have my lever cut and extended and welded back up.
    2. Find a different lever off another ATC that is longer with the same splines.
    3. Aftermarket. Tusk etc.
    It is a rider in good condition.
    '83 200X
    Aug 2016
    East of Worcester ma
    1,326
    I’m really not sure if this will help (don’t own 83-85) to compare it. If 83-87 have the same splines (99% sure they are) then both of these levers in the pic will work for you. The trx250x is 1-1/2 inches longer than a stock 86/87 200x - again no 83 here to compare its length Click image for larger version.
ID:	252111 Click image for larger version.
    Hope this helps
    Shep
    The trx is new/no rubber end yet
    Left one is a trx200sx- left out the s in pic
    May 2016
    OH Canada
    1,102
    Thank you. I will be pulling my 200X out this weekend and measure mine up.
    '83 200X
