Results 1 to 3 of 3
Thread: 1985 200x misfire
    1,628
    1985 200x misfire
    I have a misfire not able to diagnose on my 85 200x.All the simple stuff is correct.Wondering if it is a ignition issue.Tried different coil and cdi.Wondering if it could be the pulse generator,stator,rotor?
    Bowling Green KY
    3,065
    Quote Originally Posted by jays375 View Post
    I had trouble with mine once and got up in the pulse generator housing and cleaned out all the rust dust and rust off the pickup and rotor metal and that fixed my problem. It was pretty bad in there though.
    You might try that
    No loose ground wires?
    1,628
    All clean unfortunatley.Grounds are good.Bike is a new build and hasn't been run much.Ran fine until recently.
