Page 6 of 17 FirstFirst ... 4 5 6 7 8 16 ... LastLast
Results 76 to 90 of 248
Thread: KTM Three Wheeler Conversion - Done!!!
  1. #76
    Las Vegas, NV.
    2,452
    Can't you rotate one 360 and it will look like the other side.
    If he does that, he will be right back where he started.
  2. #77
    Mexico
    9,012
    Yep, that about sums it up
    These are directional and have scoops. No option to flip them around.
    It sucks to get old
  3. #78
    Manheim, PA
    5,760
    I ment rotate the tire the direction it does not rotate like the way most stack them flat.
  4. #79
    Mexico
    9,012
    I get you, but that’s 180 degrees. Unfortunately it’s not an option with these like it is on 4 Snows.
    It sucks to get old
  5. #80
    Mexico
    9,012
    Front axle arrived and it’s exactly what I wanted. Probably need to shorten one spacer (adjustments were always expected), but that’s it. Very impressed with Mr. Anonymous Machinist’s work.
    Left side tire came in as well. Had our washing machine not crapped out yesterday I’d be living the dream.
    It sucks to get old
  6. #81
    The Open Road
    4,729
    Front axle arrived and it’s exactly what I wanted. Probably need to shorten one spacer (adjustments were always expected), but that’s it. Very impressed with Mr. Anonymous Machinist’s work.....
    His name is Brent... Coworker and good personal friend.
    He does all our shop's "one-off" lathe work... as in, where you get enough material to make one piece, so it has to be right the first time.
    All I did was mill the hex head on one end so he got the majority of the coin and credit
    I'll pass on your compliments, though.
  7. #82
    Mexico
    9,012
    Using the latest in quantum red neck technology I’ve concluded that 11.875” fork centers and 2.5” of offset as at least one helpful member here is using will pretty much clear everything including rad guards. 2” might do it, but I’d likely need to loose the rad guards and reduce the turning radius as well as space the rad shrouds out a bit.
    I’m about to do some serious reading on this subject, but given the cost of a set of custom triple clamps I think I’m better off going with the 2.5 offsets rather than find out I pulled a Maxwell Smart and “missed it by that much” later on.
    Attached Thumbnails Attached Thumbnails 53FE675A-E9A4-413B-B7F2-AD21984C552D.jpeg
    It sucks to get old
  8. #83
    The Open Road
    4,729
    Your construction paper 2D modeling skills are phenomenal.
  9. #84
    Mexico
    9,012
    You should see what I can do with a napkin and a crayon
    It sucks to get old
  10. #85
    Mexico
    9,012
    Thanks to the moral support of a fellow member who we'll just call "Bob" I worked up the nerve to order the triple clamps from EMIG Racing. Gary knows the KTM clamps intimately, so all he needed was the distance between the fork tubes and the off-set in order to get started. I have a feeling they will be the focal point of the trike.
    Powder coater came through today and I got busy on the swing-arm a few nights back. What I wasn't able to do was get the tires to seat on the rims. Will try again tomorrow with a bigger compressor.
    Messing with the spacers it looks like I can get the overall width down to 48.5" if I want, or out to 51". What I can't do is use the super trick Tusk hubs I picked up unless I want to be about 53" wide, so I opted for a set of Vito's forged hubs which are the fugliest looking forgings I've ever seen. Spent about 30 minutes on each removing slag and tooling marks prior to blasting and painting. The look ok, but stockers are much cleaner.
    It sucks to get old
  11. #86
    The Open Road
    4,729
    Nice work.
    That axle makes your @$$ look fat.
  12. #87
    Mexico
    9,012
    So do my jeans and every mirror in the house, it’s a conspiracy!
    It sucks to get old
  13. #88
    Las Vegas, NV.
    2,452
    Everything is looking real nice so far.
    ...I opted for a set of Vito's forged hubs which are the fugliest looking forgings I've ever seen. Spent about 30 minutes on each removing slag and tooling marks prior to blasting and painting. The look ok, but stockers are much cleaner.
    Why not the oem hubs then?
  14. #89
    Manheim, PA
    5,760
    53: is wide. I thought 50" was wide in my toys. good progress so far.
  15. #90
    devore,ca
    1,015
    Your welds make mine look like 3 year old built my swingarm. Nice job !
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
