Results 1 to 7 of 7
Thread: 200x cam swap
    May 2018
    Lewis County NY
    32
    200x cam swap
    Does anyone know if any other camshafts are compatible with the 200x? I have heard talk of XR200 cams possibly being a match but not sure.
    Apr 2014
    Edmond, KS
    2,534
    Yes and no. Only the cam from a two valve XR200 engine will work. It is an upgrade compared to a stock 200X cam. It won't make "huge" power, but you'll make more.
    XR200 cam is a direct swap in I believe. I don't think you'll have to change anything else but it might not hurt to upgrade the valve springs and throw a set of valve seals in while you're there.
    May 2018
    Lewis County NY
    32
    Ok thanks. Is it difficult to remove the valves? Does it require special tools?
    125Mmadness's Avatar
    125Mmadness is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2017
    McConnelsville,Oh
    157
    Not too difficult but when doing it just be patient. You can make the tool to remove the keepers, just take a deep well socket (5/8" works best) and cut one side of it out to extract the keepers, compress the spring with the socket on the spring with a 6" c-clamp and pull the keepers.
    1985 ATC125M: Parts
    1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
    1988 TRX250X
    1983 ATC200E: Total Pile.
    "Bout Tree Fiddy" Master of Thy 22RE
    May 2018
    Lewis County NY
    32
    Thanks for the information!
    Jul 2018
    Washington
    9
    My cam shaft is worn and im thinking of replacing it with a xr 200 cam, is it needed to replace the springs? will it make any difference?
