85 atc250r with 86 swing arm brake caliper won’t mount up brake hub?
Ok to start off I’ve been running a yz brake caliper and decided to rebuild the 86 atc250r I had and swap it. Today I tried to do this and the alignment is off per the picture. I’m wondering if the brake disc hub is different from 85 to 86? Because I know my hub is an 85. I was checking oem Fishe and they do have different part numbers. Also an 86 atc and 86 trx have different part numbers. Just trying to narrow down my issue. Any help is appreciated.
Reason: Picture
