So I have an 85 atc250r with a lot of parts from different years I recently rebuilt top end and found out I have a long rod so I bought a spacer plate and put it together after rejetting I had very low power did a compression test and got 80psi sprayed cleaner on gaskets no idle change put oil in cylinder and got 10 more psi so new rings are on the way is there something I'm doing wrong?
