Good point, guess I was just looking for the most common possibility and options of what I'd need to do.
Tore it down today, cyl bore is 67.050mm, piston is 66.600mm. Piston moved around quite a bit, I'm sure it is supposed to be a pretty tight fit, but I've never gotten this deep before. Manual says max difference can be .045mm, I'm at .450mm, way out of spec.
Since my bore is 67.05mm, does this mean I can just get a 67mm standard bore piston and hone the cylinder and be good to go? That seems too easy, but I'm hoping that's a possibility. Is the taper limit the difference from top and bottom of bore? I think I'm right at that limit, the bottom of the bore is about 67mm.
What am I missing here or what else should I be checking? Is it common for the piston to wear and not the cylinder? Is a 67mm piston actually 67mm od or does that just refer to the bore size? It seems I'm still at stock bore size.
