Results 1 to 10 of 10
Thread: 200x 84 Rear Axle sizing - bearing journals
    Leevvii's Avatar
    Leevvii is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2016
    Australia
    216
    i have a 200x 84 and i want to replace the Rear Axle bearings. Ive noticed that the sizing of the bearing journals on the axle shaft have a heap of slack between the axle bearing's inside diameter [35mm] . The axle journals measure 34.6mm [right] and 34.45mm [left]. Is this serviceable or fixable at these diameters? What should the journal size be on the 200x axle? . I cant find any wear limits in my Clymer manual to say when the wear limit is . thanks
    n
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    pic
Name:	200x 84 Rear Axle.jpg
    n
    6,728
    I wouldn’t stress over a half a mm , just tighten the axle carrier nuts down real good and I’m sure it will be ok .
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    thanks, seems like a lot of play, do the carriers take the load? Also, seems to be a bend on one side of the axle, can they be re-straightened?
    3.0mm is the run out limit in the specs, mine must be close to that.
    n
    6,728
    Yes the axle can be straightened and as far as load on the carrier I would think most of it is on the bearings so just make sure it all gets tightened up real good . 3mm isn’t much of a bend and would be hard to even tell while riding it .
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    COLLAR, SWINGARM SIDE
    42340-965-010
Name:	200x 84 SwingArm.jpg
    Has anyone made a new one of these, or has the sizes/drawings of the item, mine has worn a hole in the collar, need to replace it i think,
    n
    May 2016
    OH Canada
    1,102
    Quote Originally Posted by Leevvii View Post
    42340-965-010
    http://www.3wheelerworld.com/showthr...ossibly-Tecate
    I think this bushing replaces that piece(?) from what I can see. This would be the route to go. Shipping.... Well that maybe a issue.
    '83 200X
    Manheim, PA
    5,760
    You dont need that peice. It does not really do much of anything. I threw tons away.
    Mexico
    9,012
    You can always make a shaft larger by knurling it with a and punch if you want a nice snug fit.
    It sucks to get old
    Leevvii's Avatar
    Mar 2016
    Australia
    216
    I brought some early last year, thanks for the link to that thread, id forgotten that the collar wasnt needed, thank you
    nearest i would figure , is that it helps stop the pivot bolt moving around, a spigot that helps keep everything "true'd up" along the pivot bolt, perhaps?, just a guess.
    n
