Upcoming Events for the Next 120 Day(s)
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 41
Thread: 200es wonít start? help?
    Apr 2014
    Australia
    521
    Hey guys, my 200es was starting ok for a while but lately it wonít fire? I have cleaned the carb and put in a inline filter too. It has a good spark but wonít start? It tries to start but still wonít! It might start for a few seconds then die, but sometimes it will start and be ok for a while then wonít start again. When I sometimes put in a new plug it will start straight away, but the old plug isnít wet? Any ideas please? Thanks Ivan
    Apr 2014
    Edmond, KS
    1,515
    Have you checked to see if it still has spark when it won't start? Have you checked valve clearances? Just a couple of suggestions. I'm not trying to tell you where you can and can't post, but you don't need to post in the new member's sections. You've been here for over four years and you've made WAAAY more than 10 posts so you could use the Trikesylvania section if you want to.
    Apr 2014
    Australia
    521
    Yes it still has spark when it wonít start! I put in the OEM carb on a few weeks ago as I had one of those chinese carbs in for a few years and had trouble with it. So I put on the OEM carb few weeks back and fired up straight away but last few weeks not to good, now it wonít even fire? Should I try and clean carb again and put rebuild kit in? Iíll ha e to check valve clearance. I didnít know about the section Iíll post in trikesylvania from now on thanks. Ivan
    Jul 2013
    USA
    635
    Did you put an inline fuel filter on it? There could be rust getting in the carburetor from somewhere. Water in the fuel can be an issue also. In a plastic container humid weather can ruin ethanol gas in a hurry. Drain the fuel bowl when it has been giving you fits maybe rig up a temp fuel supply after draining bowl.
    I edit every time!
    Apr 2014
    Australia
    521
    Quote Originally Posted by fieldy View Post
    Yes Fieldy, I did put on a inline fuel filter after a day or two! But it did run ok with the fuel filter for a day or two! I might need to take off the carb tomorrow and clean the carb again and see! Iíll change the fuel too. Yes I did drain the fuel bowl also but that didnít help. Could be the smallest piece of rust in the jet. Iíll let you know tomorrow thanks
    May 2016
    OH Canada
    1,045
    I would check fuel flow to the carb first myself. Pop the line off the carb. Turn the fuel on and watch the flow. Easy test. This will eliminate the fuel cap vent, petcock and lines. If you have good flow and suspect a fuel problem. Next step is to get into the carb.
    '83 200X
    Apr 2014
    Australia
    521
    Quote Originally Posted by Rob Canadian View Post
    Thanks Rob Iíll try that today and let you know
    Sep 2014
    Oregon
    529
    Having the same issue with mine. Fuel not getting to the engine. I’ve had it fire and run for a little bit a couple of times. Plenty of compression (blows my finger off the spark plug hole). Cleaned the carb with carb cleaner and air. Spark plug is dry. ????? I don’t know????
    Trikes owned:
    83 Honda 200x "Liquid X"
    81 DG 250r : Sold
    Apr 2014
    Australia
    521
    Quote Originally Posted by x-rider View Post
    Having the same issue with mine. Fuel not getting to the engine. Iíve had it fire and run for a little bit a couple of times. Plenty of compression (blows my finger off the spark plug hole). Cleaned the carb with carb cleaner and air. Spark plug is dry. ????? I donít know????
    Hopefully we can get them running! Iíll let you know how I go with mine! Always something wrong.
    May 2016
    OH Canada
    1,045
    A guy posted not that long ago that said he put the float in backwards... No fuel flow into the carb...
    '83 200X
    Apr 2014
    Australia
    521
    I cleaned the carb out again and new fuel with a 2 week old start plug if that and it wouldnít fire up even with starting fluid! Put in a new plug and it starts straight away! Why is it eating plugs? Plug wasnít at at all???? Any ideas
    Apr 2014
    Australia
    521
    Quote Originally Posted by ivan-083 View Post
    Then it starts and runs for about 30 seconds then dies? The idle screw is almost all the way in and I back it off to good idle then after that it stops again! It keeps starting with the new plug but wonít idle for long?
    Sep 2014
    Oregon
    529
    I guess I could have done that!! Doh!!! I’ll double check. Thanks for the info, I would never guessed I could have put it in backwards.
    Trikes owned:
    81 DG 250r : Sold
    Apr 2014
    Australia
    521
    I guess I could have done that!! Doh!!! Iíll double check. Thanks for the info, I would never guessed I could have put it in backwards.
    Any difference?
    Sep 2014
    Oregon
    529
    I had it installed correctly. I did a gravity check with the tank as with the float installed the wrong way, no fuel flow to the bowl. Correct way fuel flows into the bowl. I also tried starting with the filter off. At full choke the butterfly flutters for some reason, almost like blowback from compression. At half choke and off choke it does not flutter. ????
    Trikes owned:
    81 DG 250r : Sold
