Results 1 to 12 of 12
Thread: Ohtsu sp Wamulass 22x11x8 tire vs. Duro HF247 tire
    Mar 2018
    texas
    19
    I have a 77 Honda ATC90 that i purchased a couple months ago that had been sitting in storage for a long long time. long story short i did cleaned the tank, rebuilt the carb ect. and got it running. The bike still has the original Ohtsu tires that still have near perfect tread but the front was cracked up and dry rotted so i bought a Duro HF240 tire 22x11x8 for the front, got it mounted and installed. I guess they don't make 22x11x8 tires like they use to because the Duro is a smaller tire? Does anyone have any suggestions on a tire that matches the same size as the originals or am i just screwed?
    Jan 2014
    La
    1,062
    the closest tire to stock is the cheng shin knobbie tires https://www.amazon.com/Cheng-Shin-C8...g+shin+22-11-8. I have the cheng shins on my 200m and they ride great. We also have kenda scorpians on our 78 90 and we are veary happy with those as well.
    Mar 2018
    texas
    19
    i read on here that the Duro HF240 was the closest thing to stock, i don't really care to much about matching tread pattern as i am with the correct height and width that matches the originals to give it the same "look" i should have
    Jan 2014
    La
    1,062
    they are ok tires I also have them on my 125m but unless you have them on all the tires they are a little smaller than othe 22-11-8 tires.
    Mar 2018
    texas
    19
    damn it!!! ok so the Cheng-Shin tires are the same height/width as the originals? or is it just a lost cause looking for tires the same height and width?
    Mar 2018
    texas
    19
    damn it!!! ok so the Cheng-Shin tires are the same height/width as the originals? or is it just a lost cause looking for tires the same height and width? Do you have any pics of the Cheng-Shin tires on the 125? can you post?
    Nov 2015
    Davenport iowa
    1,144
    Quote Originally Posted by 67camaro496 View Post
    Something else to consider is that those old tires you have on and are trying to match could have been over inflated thus stretching them. Are they tubed? because if they are they are definetley stretched.
    1974 original 90 X 2
    1974 Original 70.
    Mar 2018
    texas
    19
    good point!!! as the original rear tires that are on it now rub the rear fender. When i removed the front tire from the rim halves the center of the tube was melted onto the inside center of the tire.which would indicate that they all were over-inflated for a long time. i would assume the rears are the same. yes they are tubed. That is more than likely the issue, the size difference between the two (Duro, originals) are way off as far as size. Didn't know if the Duro HF240 were smaller than the originals (not over-inflated)
    Mar 2018
    texas
    19
    DAM, did you ever get a seat cover for your 78 ATC 90? I believe i pm'ed you with some on ebay.
    Nov 2015
    Davenport iowa
    1,144
    I did get a cover, thanks. I was looking for a certain type..
    1974 Original 70.
    Mar 2018
    texas
    19
    did you get the oem reproduced heat embossed one? or what did you get?
    Nov 2015
    Davenport iowa
    1,144
    did you get the oem reproduced heat embossed one? Or what did you get?
    [attach=config]253669[/attach
    1974 Original 70.
