Results 1 to 10 of 10
Thread: Stud bolts for 84 250r help?
    Australia
    580
    Hey guys my 84 250r has had normal hex bolt and nuts for the rear wheels from the previous owner and just realised once I changed the tires over! Pain in the ass to take off. I want to buy a set and wondering if the 85 or 86 studs would fit straight onto the 84? I have the standard oem 84 rims. Below is a pic from eBay, but I hope my splines aren’t damaged now. Any help or advice would be good. Thanks Ivan
    Australia
    580
    Or what hub would replace it if it damaged might be cheaper
    Aug 2016
    East of Worcester ma
    1,328
    Just get some new hubs, many different hubs fit your axle.
    83-85 200x
    86-87 200x about 1-3/4 longer than 83-85 200x over all length
    300ex
    400ex
    86/87 trx200sx about the same width as 83-85 200x
    250x
    A few others too......
    I run aftermarket trx200sx alum hubs on this 83/84 250r axle, from outside of hub to out of other its 33-1/2 long.
    If I put 86/87 200x hubs on it would be about 35-1/2 long out to outside of hub
    I don’t think it’d be worth messing with replacing studs (just get new) you won’t be throwing tools around the shop this way
    Keep your 2- castle nuts for 250r axle though- odd size if I remember correctly
    Shep
    Australia
    580
    Thanks shep I’ll look into it! Which hub do you think is the best?
    Australia
    580
    83-85 200x
    300ex
    400ex
    250x
    Shep
    Shep so these will definitely fit?
    Aug 2016
    1,328
    Think I pd about -80 - 100 for the set I have, the trx ones u may find them cheaper? Make sure whatever u get come w/studs pressed in. Heading to work
    Shep
    Australia
    580
    Thanks shep appreciate the advice
    6,728
    All years 300ex or 400ex hubs are plentiful and cheap on eBay and will give you about 1 3/4” extra width which is a plus .
    Australia
    580
    Thanks short line! I’ll buy 300ex or 400ex then
    Aug 2016
    1,328
    Here’s my old email- pd 49x2. So $100
    Email pic is long gone, but yes they fit axle splines perfectly
    Shep
