Thread: New guy from Michigan here
    Aug 2018
    Michigan,USA
    38
    Hey guys recently picked up a 83 Yamaha trimoto 125 for 200 bucks. I got it going sort of. I cleaned the whole carb, drained old fuel and cleaned the tank, new spark plug, do need a new air filter, though I'm having trouble finding one, clead reed valves.Now it'll only start and stay running at full throttle. Once I let off it will sputter out and die, then it won't start for about 5-10 minutes. I'm out of ideas, any help is appreciated.
    Sent from my SM-J727U using Tapatalk
    Aug 2018
    Michigan,USA
    38
    Sent from my SM-J727U using Tapatalk[/QUOTE]Repost, first one was in wrong Place
    Apr 2014
    Edmond, KS
    2,534
    If your air filter is missing or has part of it missing, you are probably running lean and this could be your problem. I wouldn't run it any more without an air filter. After you replace it, then you can continue on with your testing. Running lean will cause engine damage after a while.
    Aug 2018
    Michigan,USA
    38
    Got a new air filter and the problem is still occurring. Any ideas as to where I should start looking
