Thread: 1985 70, Spark plug helicoil kit
    Feb 2015
    indio, ca
    19
    I finally found an atc 70, got it home and found that the spark plug hole has been stripped, I have never used a helicoil before and I am looking for the right size and a quality kit. Any help is appreciated thanksClick image for larger version.
    Sep 2012
    Indiana
    455
    You can drill and tap it out to the next biggest size. I can't remember off hand what it is, but it's an odd size thread spec. M12 x 1.25 I think....I believe it uses a plug from an ATC 90 then. I'd have to do some research to verify those numbers.
    Feb 2015
    indio, ca
    19
    Thanks for commenting its m10 x 1.0 called my local motorcycle mech and hes going to helicoil it same size for 60 bucks
    Sep 2012
    Indiana
    455
    I meant if you didn't want to helicoil it, you can drill the hole out and tap to a M12 x1.25. That's what I did on my 70. It's just hard to get a wrench in to tighten the plug now. But, the helicoil will hopefully provide just as good as fix.
    May 2016
    OH Canada
    1,102
    Quote Originally Posted by slicknick1818 View Post
    I wonder if they have 'TIME SERT'. It is a thread repair. I have used them in the past and works great.
    '83 200X
    Feb 2015
    indio, ca
    19
    https://www.facebook.com/736773822/v...477623823/?t=4
    Just wanted to thank everyone for your help and input.
    Does anyone know which red color rite paint matches atc's the best? I need it for my 1980 110, Thanks
    ATCKevin's Avatar
    ATCKevin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2018
    Michigan
    179
    Rustoleum gloss cherry red matches pretty close. It’s a bit brighter but looks damn good
    Sent from my iPad using Tapatalk
