Results 1 to 15 of 16
Thread: 1985 250es NO SPARK?!?!?!
    Jun 2018
    Long island Nova Scotia, Canada
    5
    Hey guys. I juat recently got an 85 250es running. It had been sitting outside for a little over a year. It was running great untill a couple weeks ago it randomly died. I checked everything and it had no spark. I got a new ignition coil and a new plug but still no spark. Any help on how to fix this problem? Thanks
    6,728
    The most common electrical parts to go bad on that machine are the ignition switch and the CDI box .
    Jun 2018
    5
    Ok how do i tell if theyre no good? Use testers? Thanks alot buddy
    gimmeamidget is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    utah
    434
    I have had the solder joints on the ignition switch break on a few of these so I would check the joints when your checking the ignition switch.
    6,728
    Ignition switch you test with an ohm meter , the CDI can only be texted by using a known good one , no real good test for your old one .
    Quote Originally Posted by Haulibut555 View Post
    Jul 2018
    Indiana
    30
    Any one have a source for an aftermarket CDI box for an '85 big red? or any success adapting the two plug style off of an '86 to fit the one plug style of an '85?
    Apr 2014
    Edmond, KS
    2,537
    My 1985 250ES Honda manual gives specs to test the CDI with a voltmeter.
    Outlaw #24's Avatar
    May 2013
    Iowa
    364
    There is a fusible link under the seat left side by Battery. Most common cause for no spark! Minimal cost
    Outlaw #24's Avatar
    May 2013
    Iowa
    364
    Haulibut555 what did you figure out on this. Do not leave people hanging that gave you ideas!
    Jul 2018
    Indiana
    30
    I'd be interested to hear what you found out, I bought two non running '85 big reds the other day and cant get spark from either. I took cdi and coil off a running trike and checked the fuse next to the battery. Look forward to gearing anything else. If I figure mine out ill update the thread
    Chopsaw is offline Just Too Addicted Arm chair racerJust too addicted
    May 2013
    St. Louis
    505
    Quote Originally Posted by Jasonh View Post
    There is a fuse on the left side , looks like a wrench . Did you check that one ? By the left rear .
    May 2013
    St. Louis
    505
    Heres a link to an old post . The link fuse is in a black box . I cut it out and wired in a new type fuse holder .
    http://www.3wheelerworld.com/showthr...s-wire-harness
    Jul 2018
    Indiana
    30
    Yeah like a soild piece of metal? not like a typical glass fuse?
    Sep 2018
    Georgia
    12
    Correct. That should be your main fuse. Most replace it with a new 20 AMP fuse with cover. Pretty easy todo.
    Jul 2018
    Indiana
    30
    Still not getting any spark. Shifting my attention to my other big red and a 110 project for now.
