Results 1 to 12 of 12
Thread: Yamaha ID Problem
    Sep 2018
    MN
    9
    Yamaha ID Problem
    First I realize their are various Threads on Vin/Serial Identification. Although I'm a new member and required to post here. Have not yet found a chart or answer that fits mine.
    Engine Serial #
    2HT-012xxx
    Its mounted on a Quad Moto 4, any searches I've tried continue to bring up Parts for various Yamahas.
    Thanks
    Monroe MI
    5,787
    2HT parts are used on many models over the years, that's why your getting so many results with engine serial number. Check the left lower frame tube for the VIN and use an online decoder to figure out your exact model.
    2,531
    The engine is mounted on a quad right now so the frame serial number wouldn't be help if it's a trike engine.
    Sep 2018
    MN
    9
    I understand that, its the engine I am trying to identify. It is very similar to my YTM225dxl, I want to know the year, model.
    Monroe
    Monroe MI
    5,787
    Sep 2018
    MN
    9
    This is what I mean Im not sure where the original motor came from and in my opinion using a frame number never gives you anything other then the stock info. Either way guess I better double check. It has no compression, I haven't taken the top end off I'm working on a Motorcycle atm but having troubles getting the ignition parts. (f x t)
    Sep 2018
    MN
    9
    Lol thanks but then what is it? I'll go get the vin brb.
    Sep 2018
    MN
    9
    Frame number
    Frame number: JY4xxxxxxxxxxxxx
    Thanks I ended up finding an identification of Yamaha Yfm225t.
    I still don't know if this is the original engine but it makes sense.
    How safe is it to actually post a VIN/Frame Number to the public?
    I appreciate your help, once I get her running again I'll post some photos.
    Monroe MI
    5,787
    10th code is the year, H=1987. Three Moto 4's were offered, 200, 225 and the 350. Check the jug for the CC displacement.
    Sep 2018
    MN
    9
    Thank you, Ill post what I can in the morning.
    Do you know where to find a free manual?
    Monroe MI
    5,787
    You can delete the VIN if you wish.
    Edit - Beat me to it.
    Monroe MI
    5,787
    Quote Originally Posted by Myrcs View Post
    PM'd you what I have.
