Thread: 185s left case gasket
    Apr 2012
    AR
    75
    Picked up an 83 185s for cheap, got it running and the left case gasket is leaking when oil gets hot. How hard is it to replace?
    Apr 2012
    AR
    75
    Pic of area
    6,727
    It’s a large O-ring on that case and you should replace the crank seal while your at it . You will need a flywheel puller , fairly easy job .
    Apr 2012
    AR
    75
    Thank you. With your help i could finally see it on the diagram. I was looking for a gasket
