Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: Mailman delivered my new 200x “motor” today
    Think of all the nice aluminum mounts and brackets we can make
    WHO IS Q?? WWG1WGA!!
    86 ATC200X Flatrack ( I may not be fast but this is one FAST 200X!!
    86 ATC350X Motocross, 86 ATC452X Flatrack!!
    07 Weekend Warrior Toy Hauler
    Aug 2016
    East of Worcester ma
    667
    Yup the mounts are going to be interesting. If it ever stops raining here I could get the bike frame out of the shed. This was in the mailbox today 30tooth rear sprocket. I like shiny parts. My front sprockets are still on the boat coming from Taiwan. Think I got the slow boat. Click image for larger version.
    Shep
    Jul 2018
    TN
    137
    Shep
    Just thinking out loud here. Would it compromise the motor if you removed the four bolts on the drive end and used a longer bolt? You could machine a hole in some plate to clear that tapered face and then bolt the plate and motor back together. You could then weld to the plate in whatever fashion you needed to. If you have access to a lathe with a large enough 4 jaw I would turn the compound slide to match that taper and get MORE surface contact. That would also make for a repeatably accurate placement so taking apart and re-assembling wouldn't get you out of alignment. Can't really see the other end so no idea how to support that side.
    Wonder what's under that black ring in between the 4 bolts? If that's a solid structure you machine a slip fit sleeve that could fit around it with 4 ears to take advantage of the existing bolts. IF that's solid under there, that would be a pretty rigid mount. Would still need something on the other end though.
    Amateur Resurrectionist
    Aug 2016
    667
    Under the black trim with the four bolts is the gear reduction (supposedly the three small gears can be changed out for 4:1 / 5:1 or 6:1 ratio- I haven’t investigated that any further.
    The motor itself has a good sturdy base/ it’s a one piece metal shroud w/fins for cooling.
    The other end has a fan, sealed shaft on bearing/ it pulls/pushes air past the ridges.
    Pics- a couple are not mine:Click image for larger version.
ID:	254489 Click image for larger version.
ID:	254490 Click image for larger version.
ID:	254491 Click image for larger version.
    Shep
    Nov 2009
    San Francisco, California
    67
    Excited to see this done!!
    Jul 2018
    TN
    137
    Ok, yeah that's not strong under there. I would stick with a face plate and longer bolts to compensate.
    You weren't wrong. Mounts are going to be interesting for sure.
    I wonder what the manufacturer has to say about mounting?
    Probably....we got your money, you're on your own.
    Aug 2016
    667
    Yup there isn’t much info/ I really need to dig to find what I’m looking for. I’ve been lurking on gocart/elec conversions forums and scooter forums for some good info though. This “Should” come together ok.
    At first I wanted to put gocart wheels on the back with 10” pvc water pipe sections over the tires. Woulda been fun but limited where to ride it (pavement).
    Shep
    Gee, a lathe, Hmmm, that would be sweel - Who's got one of those??
    This is perfect timing, I've got Brians frame just about done, 2 350X heads to fix in the mill, and last is a run of 250R head light guards to make, but those are no hurry.
    I had thought about this when I saw the Alta electric dirtbike, should probably read up on those.
    Next up, the "Shepelectric" trike...
    EDIT - Did I mention dad's an electrical engineer?? He's good too...
    Alta goodies...
    The Alta Drive and Battery:
    That's a big battery!! 1 to 3 hours run time...
    Attached Thumbnails Attached Thumbnails alta-motors-dropped--5_400x266w GEAR REDUCTION.jpg   alta-motors-dropped--6_400x266w ALTA BATTERIES.jpg
    Aug 2016
    667
    Well, I placed the motor in/ close to where it needs to be(within 1/2 inch anyway). The central weight of the motor is very close to center of frame(good), the rear brake pedal “should”be ok too. Odd that the top back motor mount is near perfect dimension as top back bolt of elec motor. That should be used when figured for mounting. The fan side will be fine for foot peg (I took the fan shroud off but it’s pretty flush w/fan when installed.
    I’m still waiting on the correct front sprockets, there getting closer(NY) should have em by Wednesday. So I still can’t do much until then. I’ll put the tripple on today (yup I’ll be dropping little balls I’m sure) on second thought maybe not it’ll be in the way (hit my head on it)....
    Here’s a couple pics:Click image for larger version.
ID:	254550 Click image for larger version.
ID:	254551 Click image for larger version.
ID:	254552 Click image for larger version.
ID:	254553 Click image for larger version.
ID:	254554 Click image for larger version.
    So far so good
    Shep
