Results 1 to 2 of 2
Thread: ATC 90 front rim/tire help
    bmw1 is offline New to the board Arm chair racerNew to the board
    May 2018
    Minnesota
    12
ID:	254537Click image for larger version.
ID:	254538Click image for larger version.
ID:	254539The 90 I have has knobby tires on it all the way around.
    The front rim does not appear to be a split rim. The rim only has 3 bolts for the hub and that is all.
    I cut the tire off because it wad dry rotted so bad. It had a tube in it as well. There are also what looks like o rings next to the bead. They are the thickness of a small belt. The rear tires did not have this "ring" next to the bead when I replaced those and the rear rims did split.
    It doesn't "look" like the front rim can be split. Is this normal? Is there a procedure for changing these tires? Does the front require a "special" tire?
    The frame indicates a US90 so I think it may have originally had the balloon tires. Someone put the knobby tires and split rims on and I have no idea what kind of machine they came from.
    Thanks.
    Cold Lake, Alberta, Canada
    3,001
    I believe those are just there to strengthen the original OHTSU tire beads. You should be able to mount an aftermarket tire back on there with no issues.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    1978 Honda XL75
