Results 1 to 13 of 13
Thread: After new battery, just a click sound but no starter going
    Sep 2018
    Calgary,AB. Canada
    25
    Question After new battery, just a click sound but no starter going
    Hi
    I'm looking for ideas.
    Just installed a new battery (tested and was 12.45w) when I press the starter button only a click sound comes from one of the two devices behind the battery.
    Any ideas on what's next?
    Thanks
    Feb 2016
    Stellenbosch, South Africa
    179
    Is your battery connections nice and tight?
    1983 Honda ATC250R
    1984 Honda ATC200X (sold)
    1985 Honda ATC250ES BIG RED
    1985 Honda ATC70 x 2
    2001 Honda TRX90
    2004 Honda TRX300EX (sold)
    2008 Honda TRX250TM
    1976 Suzuki RV90M (sold)
    1967 Vespa Primavera 125
    1958 Massey Ferguson 35
    Sep 2018
    Calgary,AB. Canada
    25
    Quote Originally Posted by deejaycee_2000 View Post
    Yes it is.. I had them filed and cleaned for a perfect connection.
    Im thinking what if the starter motor is seized? That's possible i guess
    I have to make sure all connections to the starter are as tight and clean as possible...
    Thanks
    2,531
    Is the starter solenoid good? Are you getting power out to the starter when you push the start button?
    Sep 2018
    Calgary,AB. Canada
    25
    Hi
    I do have full 12.4xVolts while pressing the start button with the ignition switch On.
    Today I pulled apart the starter and seems good. I mean I checked the continuity of all components as per the service manual and everything tested fine.
    I even bypassed the relay and touched the + of the battery pole with the cable that goes straight to the starter.
    Anyway, long story short: nothing. That starter should make an attempt to turn but nothing..
    Obviously something is not right..
    Correct me if I'm wrong but bypassing that relay and hence starter switch should have made it turn, right?
    Thanks
    6,722
    Sounds like you need a new starter motor .
    NEPA
    7,048
    Always start with the make and madel you are working on.. We are all in the blind here The relay,is called a solenoid. Yes, jumping the hot cable coming from the battery, to the cable going to the starter, eliminates all sensors/switches and the starter should spin. If you are working on a 250, sometimes the starter gears are bad from a faulty one way starter bearing,from dirty oil/lack of maintenance. Assuming your shaft spins free in your starter,your problem is most likely brushes. Either way,great quality starters are cheap on Ebay. You can also check with a good test light to see if it is sending current to the starter when the button is pushed. If it is, your problem is the starter/or something binding the starter.
    Apr 2013
    snyder texas
    456
    Quote Originally Posted by oracle View Post
    Hi
    Thanks
    Did you try the straight hook up to the starte while it was out of the motor as well as on the motor
    Sep 2018
    Calgary,AB. Canada
    25
    Hi,
    This is my new (to me) 1985 - 200M.
    Yes, the shaft spins without much resistance (while I had the starter case out). I followed the instructions on the Service Manual (remove the exhaust pipe, etc.)
    I tested the starter by touching the connection pole to the battery while it was mounted and secure. I could not take it all out cause it means take the engine side plate off along with the starter. So I left the shaft mounted and just pulled out the shell.
    I have to make sure the ground cable is perfectly attached and clean.. I thought about it last night.. maybe poor grounding..
    Here's some pics:
    Feb 2016
    179
    Yep you need to clean that up real well first, looks like it was under water ...
    1983 Honda ATC250R
    2001 Honda TRX90
    2008 Honda TRX250TM
    Sep 2018
    Calgary,AB. Canada
    25
    Yes I agree.
    I cleaned up as much as I can possible do. But still didn't work. But I didn't clean the grooves in the commuter and that's a problem...
    Also I realized there were no washers on the shaft to the back housing.. shouldn't there be washers?
    Question for you: How does it work? Does the shaft moves out or how does it engages with the crankshaft ?
    2,531
    They are always engaged and the shaft doesn't move like on an automotive engine. What keeps it from turning is a one way bearing that engages when the starter is turning, but freewheels when the engine is running.
    Sep 2018
    Calgary,AB. Canada
    25
    Oh.. ah.. Neat idea..
