Project Loose Fillings AKA The Goblin
So, I rescued this sad old 200E. Not sure of the year. Engine....I know it's trash but I might tear it down and see what's savable. Someday.
It sat outside for the last decade or better. Uncovered. No seat or fenders, in an open field.
The battery box is rotted so I cut it out and smoothed it up. This will be sporting a 200S engine anyway.
This is going to be a very long term project. I have two other three wheelers to fix first. BUT, I wanted to get this in paint before winter got here.
I want to find a 185 front end and make this a true rigid. Hence the name, Loose Fillings. Not sure what I will do with the engine but I would like to find a 200XR top end for it.
Sand blasted the frame. Two coats of etching primer and five coats of GCI acrylic enamel Marine Corp green. I had a gallon left from an M151 I fixed up years ago. I got the paint from Rapco. It's awesome paint. Semi-gloss and it dries FAST.
I'm going to paint the tank to match, provided I can find one. I know painting the fenders will be a bad idea but I have some really ratty old fenders that are whole but cracked bad. I have cut out the zip tie repairs someone done before me and used steel wire to stitch it together. If you twist the wire tight and do individual stitches, it's a hell-for-stout repair. It just looks like Frankenstein's forehead.
I have a piece of a fender that is beyond repair. I'm going to do a little experimenting with painting it. I'm wondering if lightly etching it with a sand blaster would give the paint something to grab ahold of. If I do decide to paint the fenders, this paint is good, it's meant to be recoated anytime so touch ups are a breeze. The military has been known to use a mop to apply this stuff to a deuce and a half. LOL. Surely I can make it look "Redneck Decent".
